Running Wire; Staples Needed Here? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 05:40 PM   #1
Running wire; staples needed here?
where the wires come into the picture at the top left is where they have come through the joist. Then where it is in view they come across the joist about 10" and then down through the wall header and then across and through the studs in the wall. Do I need staples anywhere in this section. The wires are a little tight, if I don't need them it will be easier. Thanks
toobhed is offline   Reply With Quote
Old 08-31-2011, 07:32 PM   #2
Rewards Points: 6,652
I would make it a slow loop, not that jumbled mess. Try to make it a little neater. If you are going to finish the ceiling, I would just try to keep it up around where it is. If you are going to leave the ceiling open, then yes, I would try to use a stacker to hold them, or a staple driven, just enough to hold, not crush.
Old 08-31-2011, 08:06 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Where is the closet staple on the 2 wires running along the joist?
The other wires do not need staples.
jbfan is online now   Reply With Quote
Old 08-31-2011, 09:34 PM   #4
I should add, why did you take part of the framing out to fit in where you did? There was no need to do so, since you should have just butted up to framing on the left.
Old 08-31-2011, 10:21 PM   #5
Well...it was the last day if framing and we came to this cold air return that joined the return from upstairs to the trunk. Its about three feet long and a foot and a half tall. I decided to remove it and replace it with a smaller profile wood frame covered with thermopan. So...
A week later I built the wood frame and temporarily covered it with plastic while I chased down the thermopan. Only problem is my measurement was off and when I went to put it in it was too wide.
the easiest way to put it in was cut a notch from the framed up wall. It's a basement, non-load bearing wall and inside a closet space that wouldn't be seen so I took the easy way out. I just didn't think it through but I think it is fine.
Here is a better angle of the wiring.
http://i1181.photobucket.com/albums/...d/49327b5c.jpg
Old 08-31-2011, 10:24 PM   #6
Sorry bout wrong pic at the end of last post
Old 08-31-2011, 10:47 PM   #7
Code05's Avatar
Rewards Points: 1,104
The wiring is fine, no staples needed. I would probably ty wrap the four wires together.
Code05 is offline   Reply With Quote
Question about running wire to storage building chris c Electrical 7 01-28-2011 02:33 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Running new dryer wire...but dryer is three plug currently. RyanD Electrical 7 08-07-2009 02:33 PM
Help needed on wire termination Phineas Electrical 4 03-24-2008 10:41 AM
8 wire to 4 wire thermostat help needed dj petey Electrical 5 01-19-2008 09:11 AM
