Old 03-08-2010, 04:37 PM   #1
running wire in finished walls
I want to run new wire from a switch up the finished wall to the ceiling. I want to install recessed lighting in the bedroom. I need ideas how to run the wire up to the ceiling without damaging the walls.
edmart2 is offline   Reply With Quote
Old 03-08-2010, 05:44 PM   #2
Attic above? Does the switch currently power a ceiling light or an outlet? Is the switch currently fed from the attic?
gnosti83 is offline   Reply With Quote
Old 03-08-2010, 09:38 PM   #3
Just call me Andrew
This is important info. If you have an attic above, makes it much easier. A basement below could come in handy too if you have one, depending on the situation.
Also, do you know which way your ceilings joists run? Parallel or perpendicular to the wall with your light switch?
Andrew
secutanudu is offline   Reply With Quote
Running new dryer wire...but dryer is three plug currently. RyanD Electrical 7 08-07-2009 03:33 PM
running wire. wjlundyjr Electrical 4 08-12-2008 09:09 AM
running wire to detached garage amakarevic Electrical 2 02-28-2008 03:17 PM
Advice/Tips on running down walls boxer1-2 Electrical 2 10-04-2005 12:38 PM
Running Conduit in new basement framed walls tben Electrical 3 12-11-2004 12:14 AM
