Running Wire In Cabinet - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 01:42 PM   #1
Rewards Points: 160
running wire in cabinet
I need to run #12 wire from two jboxes in a wall along the inside of a bathroom towel cabinet to two switch boxes that will be mounted on a face of the cabinet. We put cutouts in the cabinet wall to access the jboxes. I was planning on running TH through steel flex to protect it. Is that ok? Do I have any other options? Thanks.
philS is offline   Reply With Quote
Old 07-14-2009, 02:34 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
you can also run regular NMB through metal EMT conduit(s) and fittings
adpanko is offline   Reply With Quote
Old 07-14-2009, 07:04 PM   #3
" Euro " electrician
frenchelectrican's Avatar
I don't think so due the size and the OP mention switches so you can get this jammed up very fast if not addressed correct.
With 1/2 inch EMT conduit you only can get ONE 12-2W/G NM in there without issue.
I know some will try to jam two in there it not worth it.
Merci,Marc
Old 07-14-2009, 10:54 PM   #4
Rewards Points: 160
Bon jour -- Yup, I have to run 2 hots and two neutrals (separate circuits because one has to be GFI and the other cannot be). The distance is only a few feet.
This didn't work out as I had hoped so I have some thinking to do.
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
Requirements for running wire under mobile home? MikeVila Electrical 9 11-03-2008 08:41 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Running a ground wire T Blanco Electrical 3 01-07-2008 03:17 PM
