Running wire along sill question
Originally Posted by stickboy1375
This is only if you are running on the BOTTOM of joist.... we are talking about the sill plate and rim board.
I agree with the sited code section for under the joists and with you when stapled to the sill plate or rim joist.
That was easy!!
Now, why can't all discussions be so civilized?
All responses based on the 2011 NEC.
If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
Please check with local, county and state officials as laws may vary.
Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
