Running Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 11:25 AM   #1
Running wire
Is there a any restriction for running 2-12/3 wires through the same wall access holes to the attic?
samfox is offline   Reply With Quote
Old 09-26-2010, 04:00 PM   #2
Hello,
In Texas, I ran up to three 12/3 wires through the same wall access holes with no issues when the inspector looked at it.
david.pfeifer73 is offline   Reply With Quote
Old 09-26-2010, 04:10 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Ya, if they don't fit, don't do it.
and by fit, I mean there needs to be room in the hole to move freely or you can tear the sheath as you pull the NM through the hole.
Old 09-26-2010, 04:14 PM   #4
the Musigician
DangerMouse's Avatar
Don't forget the fire-block caulking when done.
DM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
running 2 circuits off 14/3 wire 2mshepherd Electrical 3 06-15-2010 01:16 AM
Running Under ground wire Robbro137 Electrical 1 08-21-2009 06:11 PM
wire running question ponch37300 Electrical 4 04-21-2009 04:58 PM
running wire. wjlundyjr Electrical 4 08-12-2008 09:09 AM
