Running Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 12:54 PM   #1
Rewards Points: 204
Running wire
1. Do I need a right angle drill to drill all my studs? Is there a trick to just using a regular drill?
2. Can I run my wires for my lights in my boxed in soffits (framed with 2x3s, if I attached then with staples? I would rather do this than to drill into my joists.
Thanks.
Abs777 is offline   Reply With Quote
Old 03-08-2010, 12:59 PM   #2
Master Electrician
Rewards Points: 3,920
The trick is to get your holes as close to perpendicular to the studs as possible. Holes drilled at angles are much harder to pull wire through. Why not look into renting a RA drill. My be worth it unless you already have a powerful drill.
#2. Yes you can.
brric is offline   Reply With Quote
Old 03-08-2010, 01:03 PM   #3
Rewards Points: 204
Thanks. Do you know the distance that you have to staple\secure the wire if ran in a soffit, like every so many inches\feet?
Old 03-08-2010, 01:15 PM   #4
Master Electrician
According to code it is every 54". Depending upon your inspector you may not need to staple it at all.
Old 03-08-2010, 01:43 PM   #5
Rewards Points: 1,542
The holes bored in the studs count as supports so you do not need to staple the wires as they go from stud to stud.
You would not need a right angle drill if you can get the hole nearly perpendicular (straight into) the stud using a straight drill. Where studs are much closer together such as near a corner or an intersecting wall, it is harder to get the hole straight with a straight drill.
Wires fished through intact pre-existing walls do not need to be stapled (necessitating breaking open the wall every 54 inches or so).
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Running Under ground wire Robbro137 Electrical 1 08-21-2009 05:11 PM
What is the best way to wire this? RST Electrical 8 08-18-2009 11:29 PM
wire running question ponch37300 Electrical 4 04-21-2009 03:58 PM
running wire. wjlundyjr Electrical 4 08-12-2008 08:09 AM
