Running Wire For 50A Subpanel In A Detached Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 03:52 PM   #1
Rewards Points: 1,062
Question
running wire for 50A subpanel in a detached shed
i am about to run wire for a 50A subpanel in a detached shed. i will have a circuit to connect to once i convert from an electric to a gas stove. but i first want to run the wire. i have about 30 ft of conduit buried already from the basement to the shed.
Q1: do i just need to run 3 exterior grade gauge 6 wires and can the ground wire be the same (insulated) as the hot and neutral ?
Q2: when setting the subpanel, does the ground bus connect to the ground wire coming in, in addition to the grounding rod, which i have driven into the ground about a foot away from the shed?
Old 03-15-2011, 04:44 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 378
Q1- The ground wire can be smaller, a #10 would work here.
Q2-The ground from the house and the rod connect to the ground bus in the garage.
You are going to run 4 wires to the garage right?
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
amakarevic (03-15-2011)
Old 03-15-2011, 11:37 PM   #3
Question
what's the 4th wire for ?
Old 03-16-2011, 05:29 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
4 wires are used to install a sub-panel. 2 hots, 1 neutral & 1 ground. If you're installing a sub-panel in an outbuilding, you might as well take full advantage of its capabilities.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
amakarevic (03-16-2011)
Old 03-16-2011, 10:56 AM   #5
Rewards Points: 126
Its the grounding conductor (EGC) and is required. It connects to the panel ground bar and to the rod. You need a disconnect out there too. 60 amp is the smallest you can go. The feeder can be 50 amp though.
The Following User Says Thank You to J. V. For This Useful Post:
Old 03-16-2011, 02:27 PM   #6
so the 2 hots and the neutral should be gauge 6 and the ground can be smaller (gauge 10). does it matter if the ground is insulated?
Old 03-16-2011, 02:37 PM   #7
jbfan's Avatar
Rewards Points: 378
No, but it will be an easier pull with an insulated wire.
Old 03-16-2011, 11:23 PM   #8
Electrical Supplier
Rewards Points: 150
For future reference, I thought all wire inside conduit had to be insulated.....
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 03-17-2011, 12:29 PM   #9
hey y'all, please check out my new inquiry:
THHN loose wire thru buried conduit?
much appreciated
Old 03-17-2011, 12:42 PM   #10
Experienced
Jackofall1's Avatar
much appreciated
Did and answered
The Following User Says Thank You to Jackofall1 For This Useful Post:
amakarevic (03-17-2011)
Old 03-17-2011, 05:04 PM   #11
Scared Electrician
Saturday Cowboy's Avatar
This I have not heard. I agree that it almost always would be a good idea, but where a code reference for that statement? I am not sure but I believe that a bare ground is ok in pipe?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
detached shed sub panel treerat Electrical 9 02-14-2011 11:35 AM
Correct way to wire a shed / workshop BOAH Electrical 10 01-05-2011 10:03 PM
running outdoor cable from house to detached shed above ground amakarevic Electrical 2 11-19-2010 02:16 PM
correcting existing subpanel in detached garage mtk Electrical 17 03-14-2010 01:49 PM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 09:56 PM
