Running Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 10:38 AM   #1
seansy59's Avatar
Rewards Points: 258
Running wire
How would you connect these two j boxes with NM? I would prefer to go right in between from one KO to another, but that doesn't look like an option since the strain reliefs won't fit.
Would I run the wire in a loop underneath or behind?
I tried looking for 4 gang steel j boxes that side mount, but had no luck.
seansy59 is offline   Reply With Quote
Old 08-08-2012, 10:42 AM   #2
Rewards Points: 760
How about a "conduit nipple."
Basically, a short threaded piece of pipe.
AandPDan is offline   Reply With Quote
Old 08-08-2012, 11:02 AM   #3
Master Electrician
Use a chase nipple and individual conductors.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
seansy59 (08-08-2012)
Old 08-08-2012, 11:04 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Use a chase nipple.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Old 08-08-2012, 11:07 AM   #5
seansy59's Avatar
Rewards Points: 258
Thank you all! Off to HD to get a chase nipple!
Running electrical wire jyalbert Electrical 15 04-30-2011 04:07 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
running 2 circuits off 14/3 wire 2mshepherd Electrical 3 06-15-2010 12:16 AM
Running Under ground wire Robbro137 Electrical 1 08-21-2009 05:11 PM
wire running question ponch37300 Electrical 4 04-21-2009 03:58 PM
