Running Underground Electrical, Communication, And Water - Electrical - DIY Chatroom Home Improvement Forum
Old 04-03-2009, 08:16 PM   #1
Thumbs up
running underground electrical, communication, and water
I am running underground electrical to a detached garage and want to run cable/phone, gas, and water along with it. I already have the electrical ran in 2 inch conduit done and want to add the water, gas, and cable/phone. The trench now is 2 feet deep and 2 feet wide. What are the space requirements between all four? Do they go side by side or on top of one another? Also what kind of material should I use for the water and natural gas? I am in southern california so freezing is not an issue. Any help would be greatly appreciated. Thanks.
Chavez is offline   Reply With Quote
Old 04-03-2009, 09:09 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
The water and gas can typically occupy the same trench as the electric, with some separation rules. This is typically a building/plumbing code issue. There is no NEC rule for separation.
Old 04-04-2009, 04:51 AM   #3
assuming this work is permitted (as in done with a permit) ask the inspector there are various ways to run the gas sleeved copper comes to mind and that would work for the water also but the copper will need to be painted yellow to designate it for gas
kennzz05 is offline   Reply With Quote
Old 04-05-2009, 12:07 PM   #4
Rewards Points: 128
I know plastic gas lines are yellow or have a yellow stripe. But copper painted yellow. I don't think so. Maybe a local ordinance? Never heard of this rule.
Old 04-05-2009, 12:45 PM   #5
i've seen black pipe marked yellow in industrial settings...i don't know about copper!....i would think it would be too thin
NolaTigaBait is offline   Reply With Quote
