A friend of mine recently purchased a new house, and i'll be assisting with the building of a small shed in spring. The electrical requirements are pretty low as he only wants a couple of receptacles to be used for low draw requirements. With that in mind, the plan is to run 12/2 with ground to the shed.
Living in Chicago we have a "conduit culture" as most of you know, so I don't have a lot of experience with NM. I have a neighbor that has offered some 12/2 NM-B for free to assist with the project, but I turned him down at first. As I sit here with a beer I started to think. I've used a lot of THHN in conduit, and nowadays it's also dual THWN rated. My understanding is the NM-B is THHN for the individual conductors. My question is whether these would also be dual rated THWN. If so, I could strip the NM-B outer jacket and utilize the individual line and neutral conductors in conduit (the ground is bare, so we would need to pickup a small spool of THHN/THWN for ground since it will be in buried conduit.) Thoughts?
If it was my buddy I would suggest at least 10/3 teck. No need for conduit and when he wants to add whatever you can accommodate him. These projects always start out as "All I need is this" 2 weeks later....
We've spoke about it. I'm definitely the type for a bit of overkill on a project, but the fact is that this will be a tiny shed and he's not a DIY guy (really no electric power tools to speak of.) The receptacles will predominantly be used to charge the battery on his gas lawnmower...
Why not use UF12/2 for direct burial instead of THWN in conduit? I used THWN in conduit for my shed wiring because we have sandstone and limestone to cut through and they have sharp edges that could penetrate a cable and can move even though good sand fill. But if you don't have that problem, UF cable might be much simpler.
But I would also consider the possibility of wanting more power later than he thinks he wants today.
Have always preferred conduit to direct burial in these situations.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
