Running UF On Outside Of House - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 12:32 PM   #16
Originally Posted by gregzoll View Post
I am kind of lost here. Are you wanting to run the wire for a window unit, or are you trying to hook up a central A/C unit.
Window unit in second floor bedroom.
kb01 is offline   Reply With Quote
Old 08-26-2011, 12:32 PM   #17
Originally Posted by brric View Post
Yes. I would recommend a minimum of 3/4" unless you are using UF larger than 12/2, as UF is somewhat unwieldy.
Thank you for all the help. It seems like I have several options to think about.
Old 08-26-2011, 12:33 PM   #18
Licensed electrician
Rewards Points: 1,266
Since the OP wants the receptacle inside I would say it is for a window shaker.
brric (08-26-2011)
Old 08-26-2011, 12:38 PM   #19
Rewards Points: 6,652
Is there any way, you could pull it up from the basement into the attic, instead of running on the outside, through say a plumbing stack chase, then come down inside the wall you want to put it. It would be a neater install, and not sticking out from being on the outside.
Old 08-27-2011, 09:02 AM   #20
Rewards Points: 1,192
Are you equiped to drill through 2 courses of brick and plaster?
bobelectric is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Anoying sound in house water pipes when sprinklers are ON gante Plumbing 1 06-07-2010 07:04 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
Running condensation drain into house drain log_doc_rob HVAC 2 09-07-2009 10:46 AM
