Running Service To Barn - 100 Amp - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-16-2009, 12:30 PM   #16
liscenced electrician
Rewards Points: 538
Originally Posted by 220/221 View Post
Should have stuck with 2".
Bigger is generally better.
I disagree. 1 1/2 Is already plenty overkill. Spend the money saved on a couple 1 inches
jimmy21 is offline   Reply With Quote
Old 08-16-2009, 08:39 PM   #17
Rewards Points: 502
I ran 1 1/2" for a total distance of 145' including two 90s. The pull was too hard to do manually, especially considering I didnt have any help.
I ran 3 #2s, 1 #6, and 5 #12s.
Here are a few photos of my pull.
Running Service to Barn - 100 amp-img_1777.jpg   Running Service to Barn - 100 amp-img_1778.jpg   Running Service to Barn - 100 amp-img_1779.jpg   Running Service to Barn - 100 amp-img_1780.jpg   Running Service to Barn - 100 amp-img_1782.jpg
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 10-13-2014, 07:56 PM   #18
Rewards Points: 6
Something I read said when I run a 100A circuit to the barn I need to keep the neutrals and grounds separate in the panel. My NEC book is old and I just moved so don't know where it is anyway but am curious why the neutrals and grounds need to be kept separate.
Injun is offline   Reply With Quote
Old 10-13-2014, 08:05 PM   #19
Rewards Points: 3,396
objectionable current
ritelec is offline   Reply With Quote
Old 10-13-2014, 08:08 PM   #20
Rewards Points: 6
Ok I have found information stating the neutral and ground must be separated in the subpanel. So I use a ground rod there and attach it to the ground bar and all should be good.
Old 10-13-2014, 08:21 PM   #21
Rewards Points: 6
Excellent, he made it all simple. I will follow the code.
Running power to barn, need help. Bearcamp Electrical 7 05-05-2009 09:36 PM
100 AMP service to barn tripelranch Electrical 1 10-16-2008 05:55 AM
Running Power to a horse barn Lusco Electrical 3 04-26-2008 03:34 PM
help running electricity to barn kavik001 Electrical 10 09-10-2007 04:45 PM
electrical service to barn bsteven Electrical 1 04-18-2005 08:43 PM
