Running Rope Lights From A Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 03:29 PM   #1
Rewards Points: 225
running rope lights from a switch
Hi,
I hope some of you electrical experts can help me out here. I'm trying to run some rope lights in my safe that runs to a basic switch mounted inside the safe.
my local home depot has 25 foot rope light sets on clearance for $10 per set. I was going to pick up 2 sets since my safe is tall, and for $10 per set, I figured why not.
so, my plan was to connect the two sets together using the connectors the rope lights come with, run the one electrical cord to an existing outlet that sits behind my safe and to cut the plug off of the other end so that I can run that end into a handy box and then wire it up to a switch.
the question I have is whether or not that would work?! and, if the electrical cord that comes with the rope light does not reach to the outlet, can I plug that into a surge strip that is then plugged into an outlet?!
Thanks,
Andrew
andrewjs18 is offline   Reply With Quote
Old 03-05-2012, 09:47 PM   #2
seansy59's Avatar
Rewards Points: 258
Cutting the plug off would violate the UL listing, and worse, defeat the fuse protection on the light set since they are built into the plugs.
Run a basic powerstrip from an outlet with a cord length you need. That would solve the switch problem and the cord length problem.
Or. Install a switched outlet to plug the rope lights into instead of hardwiring them.
Safety first, convenience second.
seansy59 is offline   Reply With Quote
Old 03-05-2012, 11:02 PM   #3
" Euro " electrician
frenchelectrican's Avatar
How ya going to drill thru the safe ??
That part I am instering to see how you can figure it out due most safe are thick walled they can be pretty tough to drill but if you have proper drill bits ( note: I say more than one set of drill bit will work ) due most safe will have combation of steel and concrete in there.
Merci,.
Marc
Old 03-05-2012, 11:07 PM   #4
Rewards Points: 13,732
Rope lights give off very little light, why out you pick them?
No way you could even read with them on.
Old 03-07-2012, 12:18 AM   #5
Rewards Points: 225
how would I wire a switched outlet?
I slightly modified what I was originally going to do.
what I'm thinking of doing is run an extension cord into the safe, cut off the male end, wire it together with the rope lights and then wire that to a switch.
Merci,.
Marc
the safe came pre-drilled with an electrical hole in the corner of it, like almost all modern safes do.
I bought two sets, they should be decent enough for what I'd need.
Double combination switch not turning on lights Mwright1978 Electrical 4 12-31-2011 06:37 PM
Wiring receptacle > switch > motion sensor lights Van Home Electrical 11 08-09-2010 11:27 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
How to switch fluorescent lights Carissa Electrical 3 08-16-2008 02:28 PM
