Running Romex Up From Basement To Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2006, 12:21 PM   #1
Running Romex up from basement to attic
I'm in the process of running a new circuit from the basement panel up to the attic, which I will use to feed into the master bedroom for a new outlet. I have a path from the attic to the basement running near the sewer vent pipe. It is a straight shot and the easiest path I can find from attic to basement. 2 questions:
1) Is this an acceptable path to use for the electrical cabling?
2) I can actually see from attic to basement through this space, making this a fairly easy run--however, I don't know how I'd secure the cable, except at the top (attic) and bottom (basement). The run is about 40 feet, top to bottom. Any suggestions? Is it acceptable to leave it unsecured through this area?
Thanks for any advice.
tra999 is offline   Reply With Quote
Old 07-25-2006, 04:21 AM   #2
Use the stink pipe chase and secure it top and bottom as you have already figured out. You do not need to secure wire that is fished in wall chases.
jwhite is offline   Reply With Quote
Running coax from attic to room below, via exterior wall? curls00 Electrical 13 08-15-2007 02:18 PM
Romex laying across joist in attic? Doug Crf Electrical 4 08-17-2006 04:53 PM
Running Romex in the attic mdalli Electrical 7 07-06-2006 05:35 PM
running ethernet through attic null_pointer_us Building & Construction 3 05-15-2006 05:08 PM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 12:41 AM
