Running Romex Down A Bulkhead - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2012, 07:59 AM   #1
Rewards Points: 640
Running romex down a bulkhead
I need to run a line down the length of the room into a column, there is no easy way to get this line there besides running it inside the bulk head which covers the HVAC ducts and a 8" I beam.. The bulk head is framed like a OSB I beam then 2x4's down the center to form a ladder 16" O.C."
the ladder is held together by 2x4's which then screwed into the OSB. (Picture attached to show what I mean)
The only place I could easily run a line is where I marked it in red on the drawing... Is this allowed? It would be 2" in from all sides... 1 1/2" for the 2x4 and another half inch of OSB.
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 08-29-2012, 08:14 AM   #2
Licensed electrician
Rewards Points: 1,872
That would be fine. Secure the cable to the side of the bulkhead.
A Couple of Questions About Running Romex Wire Near Utilities toobhed Electrical 4 08-26-2011 08:15 AM
Fishing Romex through walls Tetranitrate Electrical 6 07-09-2011 06:12 AM
Payne gas furnace - blower fan running continuously Ed40 HVAC 0 02-05-2011 02:19 PM
Running ROMEX into Conduit tlj Electrical 15 11-05-2009 07:20 PM
Running romex along a wall in a closet Red Squirrel Electrical 16 10-02-2009 08:44 PM
