Running Romex Along A Wall In A Closet - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2009, 01:48 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 68
Running romex along a wall in a closet
I had a new closet built, the one plug controlled by the switch is in that closet. I'm thinking of wiring a light in and out of the closet so the switch can still control a light for the room. I'm thinking of hooking some romex up to a 3 prong plug and then running it along the wall inside the closet and then to an octogon box on top of the closet for the light.
Is there anything wrong with running romex and having it exposed this? What about if I buy some of those plastic raceways and glue them along the wall?
Old 09-23-2009, 01:55 PM   #2
Licensed electrician
Rewards Points: 1,258
At least in the US NM-B is not for use with a cord cap. There are also strict clearance requirements.
Old 09-23-2009, 06:24 PM   #3
A cord cap on romex =
It's a big red flag that says
It is WAY easier just to do it properly
It's a closet wall. Just cut and patch the drywall. It aint rocket science.
220/221 is offline   Reply With Quote
Old 09-26-2009, 07:35 AM   #4
If you do not want to break and patch, consider using Wiremold. Using Romex as a line cord is butchery. But are you also intending to control another light in the room from a switch in the closet? Need clarification.
oilseal is offline   Reply With Quote
Old 09-26-2009, 07:46 AM   #5
Prior owner did that in one closet - no plug - just the wire to 2nd floor
I took the wire out, drilled holes & put it in the wall
Old 09-26-2009, 06:22 PM   #6
Wire Chewer
Rewards Points: 68
This is what I basically want to do.
Inside the closet is the plug (on same wall as switch) controlled by the switch that is outside of it. So I'd run my wire inside the closet then at the top of the closet I'd make a hole with a jbox on the outside of the room and put a light fixture.
If Romex is not really the right type of wire to use what would be good? What about extension cord wire? I was thinking romex mostly because it is still going to be a permanent installation. Or what about armored cable, is that a better choice?
Oh and reason for this setup is that closet did not exist before, it was added. The bath tub in the washroom was actually moved inside the old closet and it got closed in.
Old 09-26-2009, 06:24 PM   #7
Rewards Points: 6,652
Easy way, is to remove the Drywall from inside the closet, run the wire like it should be, then replace to repair. Why was this not done when the closet was built in the first place?
Old 09-26-2009, 09:05 PM   #8
Wire Chewer
Rewards Points: 68
I never thought of doing it till it was all closed in, now is too late to start ripping drywall and plastering. I got all my stuff in there and everything and living in the house now. Worse comes to worse I'll run an extension cord with a lamp outside the closet. Suppose another option is to fish wire from the attic and do it that way.
Old 09-26-2009, 09:08 PM   #9
The outlet that is controlled by the switch is near the top of the closet?
Old 09-26-2009, 09:17 PM   #10
Wire Chewer
Rewards Points: 68
It's inside at normal ground level, I'd run the wire up along the corner of the closet wall then the wall/ceiling, then to the middle of the closet header above the doors, then at that point I'd make a careful hole in the drywall to run the light jbox. I'll probably use plastic covers for the wire or something. Maybe even crown molding. Does not really have to be 100% as it will all be inside, I just don't want huge holes in drywall either. :p
Old 09-26-2009, 09:20 PM   #11
You'd have to use wire molding made for wire in order to meet code
Why not just an outlet at the bottom right or left?
I assume you want the light for the room, not the closet?
By our code you probably should have an outlet on the right wall of the closet
Old 09-26-2009, 09:48 PM   #12
Wire Chewer
Rewards Points: 68
Yeah I want to light the room itself (side style fixture above closet door). While I'm at it I'll probably just light the inside too.
Looks like wire molding it is, I'll have to check around the hardware stores see if they cary it.
I've seen BX cable surface mounted on walls in public/industrial places. Is this another acceptable way I could do it, or would this method not apply in a residential setting?
Old 09-26-2009, 09:54 PM   #13
I'm not sure on the BX, haven't used it
Old 09-26-2009, 10:24 PM   #14
dSilanskas's Avatar
You can run romex on the surface of a wall as long as it is not exposed to anthing that will damage the wire. As far as putting a plug end on the romex
dSilanskas is offline   Reply With Quote
Old 09-27-2009, 07:00 AM   #15
If there's a chance of coming down from the attic it's worth a try. Otherwise, cutting a channel in sheetrock or plaster is not impracticable and is done quite usually as an accepted method. Don't feel alone in your plight RS, electrical planning is commonly neglected by DIY folks and pros as well. This proves that nobody is perfect; as much as I've preplanned, a shortcoming somehow crops up. And by the way, if you'd use BX you'd just as well use Wiremold for reasons that should be obvious.
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
Wire closet shelf coming out of wall... Iluv4cats General DIY Discussions 16 01-15-2009 06:39 AM
Running Romex up from basement to attic tra999 Electrical 1 07-25-2006 05:21 AM
Running Romex in the attic mdalli Electrical 7 07-06-2006 06:35 PM
running ethernet through attic null_pointer_us Building & Construction 3 05-15-2006 06:08 PM
