Old 02-19-2009, 11:39 PM   #1
Send a message via AIM to Bocolo
Running Romex
I have been "mapping" my entire house for a complete rewiring I am going to have to do. One quick question: I will be running some romex to a room that will eventually become a bathroom. Since I am planning on remodeling this room I would like to have some extra 12/2 romex so that I may change the location of receptacles or lights if necessary. Can I leave extra wire in a "loop" on top of the attic? Or should I run the wire along the longest path so that after the remodel I can change the path to a shorter path and this way have the extra romex? Thanks for your time and input.
Bocolo is offline   Reply With Quote
Old 02-20-2009, 12:24 AM   #2
DIY'er
jamiedolan's Avatar
Running Romex
My opinion...
Leave a big old loop and don't connect the wire at either end. Label it clearly "abandoned in place - for future use - disconnected"
Jamie
Jamie Dolan - Neenah, WI
Need Help Uploading Photos?
jamiedolan is offline   Reply With Quote
Old 02-20-2009, 05:28 AM   #3
Running Romex
Thanks for your time Jamie. Never thought about leaving it "abandoned in place". I think that would be best. Thanks.
Old 02-20-2009, 08:23 AM   #4
Running Romex
In fact, its a code requirement.
rgsgww is offline   Reply With Quote
Old 02-20-2009, 08:32 AM   #5
Running Romex
What I was originally thinking was making all the connections from panel to receptacles and lights in the current room configuration. Once the room was remodeled I think the possibility exists of having to move some lights and receptacles around so I wanted enough cable to be able to make these moves. That is why I asked about "long" runs but the "abadoned cable" idea is probably best. Even better if it is a code requirement. Thanks for your time.
Old 02-20-2009, 10:53 AM   #6
DIY'er
jamiedolan's Avatar
Running Romex
You can run it and hook it all up the way the lights are now, but install a second unconnected abandoned cable up in the ceiling for future use.
Jamie
Old 02-20-2009, 10:58 AM   #7
Running Romex
Thanks, that would really work well. Thanks for your time.
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 06:01 PM
Sump pump running as much as 20 times per day Shpigford Plumbing 7 06-23-2008 10:33 AM
running 14-2 romex tibbsy Electrical 4 08-25-2007 09:34 PM
Running Romex up from basement to attic tra999 Electrical 1 07-25-2006 05:21 AM
Running Romex in the attic mdalli Electrical 7 07-06-2006 06:35 PM
