Running A Receptacle Of A Light Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2013, 07:51 PM   #1
Running a receptacle of a light circuit
I read on here yesterday that an outlet can not be run off a circuit that supplies a light. Is this always correct? I would like to know exactly why. If the light circuit only feeds one light and is 20 amp and 12/2 wires, then would it be okay to do?
paintdrying is offline   Reply With Quote
Old 01-27-2013, 07:54 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
No, the receptacle can not be used with a switch loop.
As long as you have a hot and a neutral, you are good to go.
jbfan is online now   Reply With Quote
Old 01-27-2013, 08:09 PM   #3
Okay, I understand. I just want to make sure I do not learn to do electrical work the wrong way in the beginning.
Old 01-27-2013, 08:12 PM   #4
Licensed electrician
Rewards Points: 1,872
Certain circuits like for bathroom, kitchen, dining and laundry receptacle circuits cannot provide power for lighting. What does the circuit you want to tap provide power to?
Old 01-27-2013, 09:41 PM   #5
Okay, it is in a unfinished basements with bare concrete walls. The circuit i want to tap into feeds six lights ( 60 watt incandescent pull chain) and one smoke detector. All running into the basement, it feeds nothing else. I need to drill through the floor, the base of a built in, through the side of the cabinet, into a fake chimney( 2x 4 framing covered with particle board) then out the front of the particle board into a box for the receptacle. Approximately 12 feet, or 40 feet too the panel box. The circuit feeds a 60 flat screen tv only. Their is presently a receptacle in the cabinet wired from the ceiling so i can not get to that circuit. The tv will draw maybe an amp. I originally wanted to run from the panel but it is full. My electrician was the one that said to tap the light circuit. He retired a few years ago so I always double check him against someone with a current license.
Old 01-28-2013, 03:34 AM   #6
That circuit sounds fine.
Old 01-28-2013, 07:46 AM   #7
joed's Avatar
Rewards Points: 13,712
Unfinished basement with bare concrete walls requires GFCI receptacles.
Old 01-28-2013, 08:27 AM   #8
This circuit goes through the floor, up into the first floor, does that then require a gfi?
Old 01-28-2013, 11:28 AM   #9
joed's Avatar
The receptacles on the unfinished basement concrete wall must be GFCI.
light receptacle vs. switch test device amakarevic Electrical 5 03-23-2012 05:15 PM
confusion with track light stephenbishop Electrical 7 03-10-2012 01:37 PM
Running 50 Amp 250 Volt Circuit 451stroker Electrical 8 12-07-2011 07:10 PM
Stairway light powered from GFCI circuit? jeh179 Electrical 10 03-23-2011 08:57 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
