-   -   Running a receptacle of a light circuit (http://www.diychatroom.com/f18/running-receptacle-light-circuit-170310/)
paintdrying 01-27-2013 08:51 PM
I read on here yesterday that an outlet can not be run off a circuit that supplies a light. Is this always correct? I would like to know exactly why. If the light circuit only feeds one light and is 20 amp and 12/2 wires, then would it be okay to do?
jbfan 01-27-2013 08:54 PM
No, the receptacle can not be used with a switch loop.
As long as you have a hot and a neutral, you are good to go.
paintdrying 01-27-2013 09:09 PM
Okay, I understand. I just want to make sure I do not learn to do electrical work the wrong way in the beginning.
Jim Port 01-27-2013 09:12 PM
Certain circuits like for bathroom, kitchen, dining and laundry receptacle circuits cannot provide power for lighting. What does the circuit you want to tap provide power to?
paintdrying 01-27-2013 10:41 PM
Okay, it is in a unfinished basements with bare concrete walls. The circuit i want to tap into feeds six lights ( 60 watt incandescent pull chain) and one smoke detector. All running into the basement, it feeds nothing else. I need to drill through the floor, the base of a built in, through the side of the cabinet, into a fake chimney( 2x 4 framing covered with particle board) then out the front of the particle board into a box for the receptacle. Approximately 12 feet, or 40 feet too the panel box. The circuit feeds a 60 flat screen tv only. Their is presently a receptacle in the cabinet wired from the ceiling so i can not get to that circuit. The tv will draw maybe an amp. I originally wanted to run from the panel but it is full. My electrician was the one that said to tap the light circuit. He retired a few years ago so I always double check him against someone with a current license.
Jim Port 01-28-2013 04:34 AM
That circuit sounds fine.
joed 01-28-2013 08:46 AM
Unfinished basement with bare concrete walls requires GFCI receptacles.
paintdrying 01-28-2013 09:27 AM
This circuit goes through the floor, up into the first floor, does that then require a gfi?
joed 01-28-2013 12:28 PM
The receptacles on the unfinished basement concrete wall must be GFCI.
