Originally Posted by ribertgropius
I took a measuring wheel to double check my distance today; am only 250'. Still need to bump to a heavier wire than #6?
And perhaps I misunderstood: I thought all I needed to run was three wires from the main panel, and then a separate ground at the new panel. I know I am missing something here...
Am I correct in thinking the two grounding rods are for the new panel in the barn: one for the ground and one for the common?
Thanks!
Robert
You may get away with 3 conductor set up
only if you are on 2005 or 2002{one of the two } and earlier codes but if your are do required 2008 code then no you must use 4 wire feeder
But seriously I will still recomoned you run in 4 conductor set up so you don't have to worry about the code related issue come back and haunt ya.
but you will still have to use 35mm˛ { 2 AWG } conductor size and I mention copper here but if you want to use alum conductor you will have to bump up one size larger like 50mm˛ { 1 AWG }
For long run do not try to excessed 360° total bends but I rather keep at 270° or less it easier to pull.
with 35 or 50mm˛ conductors you will need 1.5 inch conduit size eaiser to pull with this distance and make sure you use plenty wire lube to make it slide easier.
Merci,Marc
