Running Power Outdoor To Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2010, 10:05 PM   #1
running power outdoor to subpanel
I am planning on having a sub panel installed in my garage. My main panel is on the back of my house and as far from the garage as it can be. Would it be ok to run the line from the main panel out doors? My 220 air conditioner line is outdoors about 6 inches off the ground and runs along the same path. I am thinking it would be easier to do this than snake a line up through the wall, through the attic, and then backdown the garage wall.
beerdog is offline   Reply With Quote
Old 02-15-2010, 10:52 AM   #2
Rewards Points: 160
Either way is fine. If you run it outside you need to use conduit and wires rated for wet locations.
In my opinion running it the hard way is the best way. Up - Over - Down. This way you can use a cable if you like.
Old 02-15-2010, 11:31 AM   #3
I hear ya. Local codes require I have to use conduit in my county. I plan on having an electrician do it and having it inspected. I guess I will see what the electrician says. I have not talked ot anyone yet.
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 07:45 PM
Subpanel for now, convert to 2nd main panel later? abmiller67 Electrical 2 08-27-2009 01:44 PM
Can I give 12V DC to power inverter through PC Power supply? inverter General DIY Discussions 3 07-06-2009 09:38 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
