Running Power Out To The Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 08:22 AM   #1
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Running power out to the shed
I recently built a 12'x 16' shed about 75' from the house.
I'd like to run power out to it.
I just want a couple of lights and an outside outlet.
Not going to run any equipment or fridges.
Minimum requirements and suggestions?
tcleve4911 is offline   Reply With Quote
Old 11-10-2011, 08:47 AM   #2
Licensed electrician
Rewards Points: 1,758
You could run something as simple as 12-2 UF out to your shed and have a 20 amp circuit for your lights and receptacle.
Circuits to outbuiilding are very common on this board. You can use the search function and then come back with any questions that are unanswered.
tcleve4911 (11-10-2011)
Do I have any more electrical service capacity? (Power for Shed) Magnus357 Electrical 7 10-13-2012 08:52 AM
Running electric to a shed msajeep Electrical 18 04-13-2011 05:59 PM
running wire for 50A subpanel in a detached shed amakarevic Electrical 10 03-17-2011 05:04 PM
Running power to pool equipment???? kj 47 Electrical 10 03-27-2010 05:02 PM
running DWV pipe from shed to house amakarevic Plumbing 3 03-14-2008 03:11 PM
