-   -   Running Power to a horse barn (http://www.diychatroom.com/f18/running-power-horse-barn-20342/)
Lusco 04-26-2008 08:06 AM
Needing some help on determining if I have enough load capacity in my existing load center or should I have a new line run from the transformer box. What is the recommended wire? Here is what I have currently in the house. I would like to install a 100amp load center in the barn. Any help would be appreciated.
Thanks, Scott
House
200 amp load center
10 = 15amp circuits
9 = 20 amp circuits
well pump = (2) 20 amp circuits
A/C = (2) 30 amp circuits
Range = (2) 40 amp circuits
Dryer = (2) 30 amp circuits
4 lugs available
Expected load for the barn (32x40 pole barn)
4 stall lights (flourecent)
4 electrical outlets for water bucket deicers
1 large mercury outside pasture light
6 canister lights for under the lean-to
4 additonal light fixtures inside
6 misc electrical outlets inside
1 gfi for deicer outside
1 gable fan for exhaust
4 fans for stalls
I am approximatly 300 feet from the side of the house to the barn.
Termite 04-26-2008 10:46 AM
Coming off a house already served with 200 amps, that is a heck of a lot of demand in the barn.
Considering that you're 300 feet from the house (big money for wire and considerable voltage drop), I would advocate running another service to the barn from the transformer instead of tapping from the house. Your utility company might be willing to set another meter for you and pull the service if you can convince them that they're going to sell a lot more electricity.
jrclen 04-26-2008 11:10 AM
Thanks, Scott
House
200 amp load center
10 = 15amp circuits
9 = 20 amp circuits
4 lugs available
4 fans for stalls
That is a fairly light load for a 100 amp service in the barn. I would install a 100 amp breaker in your house panel and install a 100 amp main breaker panel in the barn. Use 1/0 1/0 1/0 6 aluminum feeder from the house. 1/0 size for the hots and neutral and the 6 for a ground. Also install a ground rod at the barn. Any other questions, just ask.
HandyPete 04-26-2008 04:34 PM
jrclen...What he said. :thumbsup:
