Running A Portable Generator 150' Away From The House - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 11:50 AM   #1
Running a portable generator 150' away from the house
Will hard wiring a manual transfer switch using 10 gauge wire running underground about 150' wired to a 30 amp (4-prong) power inlet box connected to a 7500watt generator work?
mrbillz is offline   Reply With Quote
Old 09-24-2011, 12:00 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Yes, but I'd bump it up to #8.
Old 09-24-2011, 08:15 PM   #3
Missouri Bound's Avatar
If it's portable why not bring it closer? That's a long run, and 8/4 isn't cheap.
Old 09-24-2011, 08:31 PM   #4
Code05's Avatar
Rewards Points: 1,104
I am guessing he has a shed to house it in bad weather and/or maybe also does not want the fumes and noise at the house.
Code05 is offline   Reply With Quote
Old 09-25-2011, 01:45 AM   #5
Rewards Points: 1,192
Calculate what is going to be your total load, and then worry about voltage drop.
bobelectric is offline   Reply With Quote
Old 09-25-2011, 08:37 AM   #6
That's right. I want to use the shed that's in the back yard.
Old 09-25-2011, 10:01 AM   #7
biggles's Avatar
i ran #6-4 wire on a 3500 genny 100' between the garage and the CB panel not even close to what might be considered a load on either leg in the depth of a blackout yet...but over sizing the run out doesn't hurt if you have 115v out there already mounting an emergency light right above the genny makes it easy on the night time flip when you drop the pole..then when you start the genny you have your typical 100watt bulb going IF NOT... filling gas..checking the oil with a flashlight in your mouth is BS
Old 09-26-2011, 12:50 AM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,920
I second Biggles' recommendation for an emergency light above the generator. You can pick them up cheap or free used, and it's SO NICE to have automatic light around the generator when the power goes out.
mpoulton is offline   Reply With Quote
Old 09-26-2011, 03:54 AM   #9
Then you need another normal power feed to maintain the battery pack.
Old 09-26-2011, 08:13 AM   #10
I assumed the shed either has power, or would have power when he's done with this project. Helps to have a trickle charger for the generator battery, too.
Old 09-26-2011, 09:49 AM   #11
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
Mine is about 100' away, and it works great! Really cuts down on the noise. Here is a pic of my little generator house in the woods.
Oh-Fudge is offline   Reply With Quote
Old 09-27-2011, 09:51 AM   #12
Hey biggles,
How did you connect the generator to the CB panel? Did you disconnect the neutral to ground connection in the generator?
Mike
Mike2401 is offline   Reply With Quote
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
Running a new line for stove in conduit on outside of house nocsec Electrical 14 12-31-2010 08:52 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Anoying sound in house water pipes when sprinklers are ON gante Plumbing 1 06-07-2010 06:04 AM
House fan started running on its own! Kamishki Electrical 4 06-02-2010 05:44 PM
