Running An Oven In 2.5mm Flex? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2012, 05:54 PM   #1
Question
running an oven in 2.5mm flex?
I have a fan assisted oven which draws about 12A maximum but the nearest socket outlet is already part of a ring main which is pretty fully loaded so I decided that it'd be best to plug it into the other ring main in my house and the nearest socket is about 15metres away, would a 2.5mm flex be ok for this or should I opt for a 4mm? Or would a 4mm have a knock on effect on something else
peterdevlin1 is offline   Reply With Quote
Old 04-24-2012, 06:00 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,096
With most cables bigger is better !
but for 12a a 2.5m cable would also be fine.
dmxtothemax is offline   Reply With Quote
Old 04-24-2012, 06:01 PM   #3
Rewards Points: 582
sorry really don't follow you on pluging in an oven to a standard outlet....but I would install a dedicated circuit for just the oven....no other appliances .....
Old 04-24-2012, 06:04 PM   #4
Well the oven comes with about a 1 metre flex already attached with a plug top, like most ovens I've ever came across
Old 04-25-2012, 09:15 AM   #5
Ben's, think its a countertop convection toaster oven.
Evstarr is offline   Reply With Quote
The Following User Says Thank You to Evstarr For This Useful Post:
ben's plumbing (04-25-2012)
Old 04-25-2012, 05:54 PM   #6
Rewards Points: 582
sorry for misunderstanding...... Iam getting old....
Old 04-25-2012, 05:55 PM   #7
Rewards Points: 582
thanks guy.....
Old 04-25-2012, 06:01 PM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Due to the wording, I'm assuming this isn't following the NEC, but i would not suggest rewiring a counter top appliance.
I am not going to comment on hardwiring a "normal" convection range due to the code differences.
Old 04-26-2012, 01:12 AM   #9
Originally Posted by ben's plumbing
thanks guy.....
Lol sorry....
Old 04-26-2012, 02:29 AM   #10
" Euro " electrician
frenchelectrican's Avatar
K_buz.,
If you did catch the key word at the first posting of OP's part the key word is ring circuit so the OP is from UK area so nothing from NEC can be used at all.
peterdevlin1.,
If this is part of kitchen item it have to be on the Kitchen circuit not the general ring circuit because if you used the ring circuit you have to use the fused plug if you don't have fused plug you have to run a new 2.5mm2 T&E cable or other types as long your code do allow it.
12 amp is right on borderline with 16 amp fuse or breaker rating unless you have new 20 amp circuit you will be fine. ( BTW it have to be on RCD protection so you will have to use the RCCO or RCD breaker one of the two )
Merci,
Marc
Tags
2.5 , cooker , flex , oven
only 1/4 inch of frame & wall on each side of wall oven tentativentexas Appliances 1 09-27-2010 07:56 PM
Oven Door question for Amana Gas Range ChrisJJ Appliances 1 09-13-2010 07:48 AM
Oven - 230v - disconnect? CZSteve Electrical 2 06-13-2010 06:56 PM
sediment trap with gas flex line? diggerdave Plumbing 10 02-11-2009 07:14 PM
