Running Outlet To Island Thru Slab - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 12:45 PM   #1
running outlet to island thru slab
We are installing an island in new kitchen- Kitchen is on a slab... the island will be about 2.5' from the wall. The existing floor is concrete slab with plywood over it (yes- that's original to the house- not sure why)- What is best way for me to get some type of conduit from the wall out to the island location? I can make a channel thru the plywood and then cut into the slab with a saw to make a inch wide channel. Not sure how deep I need to make it though- What type of conduit do I need to carry electrical cable out there?
skinut2234 is offline   Reply With Quote
Old 09-19-2012, 01:10 PM   #2
Resi EC
Rewards Points: 252
Yes into concrete, atleast 2 1/2 inches.
When you pull up the plywood, might want to check for moisture.
EDIT: forgot ... 3/4 PVC should be fine
Gac66610 is offline   Reply With Quote
Old 09-19-2012, 01:16 PM   #3
Rewards Points: 344
I would hope there is a vapor barrier in place. Otherwise, rip it all up and replace.
herdfan is offline   Reply With Quote
Old 09-19-2012, 02:15 PM   #4
Resi EC
Rewards Points: 252
Even with vapor barrier, you could still have moisture under it.
Are you saying this would be okay?
Old 09-19-2012, 02:32 PM   #5
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Use PVC conduit just under slab. Run UF cable through the conduit. Romex is prohibited.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-19-2012, 02:33 PM   #6
Rewards Points: 344
Yes. The key is too keep the moisture out of the house and the floor. Current method of slab foundation is to put a vapor barrier under the concrete, but OP didn't indicate how old the house was, so a second barrier sure won't hurt.
The Following User Says Thank You to herdfan For This Useful Post:
Gac66610 (09-19-2012)
Old 09-19-2012, 04:37 PM   #7
bbo
i always though dual vapor barriers were a no-no since you effectively trap moisture/dirt/etc between them effectively creating an enviroment for growing things.
with one vapor barrier, you give things the opportunity to dry out should they get moisture in that area.
anyone able to enlighten me on this? is this dependant on location?
bbo is offline   Reply With Quote
Old 09-19-2012, 05:01 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,858
In most circumstances, only one vapor barrier is appropriate. Dual vapor barriers with any sort of organic material between them are a mold disaster waiting to happen. However, concrete doesn't mold on its own, and it is happiest (and strongest) when permanently moist. A vapor barrier over and under the slab would not be a problem unless there were organic material in there somewhere.
mpoulton is offline   Reply With Quote
The Following 2 Users Say Thank You to mpoulton For This Useful Post:
bbo (09-20-2012), Gac66610 (09-19-2012)
Old 09-19-2012, 08:30 PM   #9
Resi EC
Rewards Points: 252
So I'll say to the OP, if you cut through a vapor barrier make sure you get it sealed up well.
Old 09-19-2012, 09:19 PM   #10
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Run a pole from island to ceiling then fish it across to feed it
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 09-19-2012, 10:09 PM   #11
thanks all- definately no vapor barrier there now- I was hoping to leave the plywood in place but I guess I need to rethink..... so as far as the channel goes from the existing wall out to where the island will be.....:
i will cut the plywood and then cut the slab with a diamond blade at least 2.5' down and chisel out a channel. Then I need 3/4 inch PVC conduit-and UF cable running through it- I'm guessing once it's in- cover the PVC with some type of mortar to keep it firm?
Old 09-19-2012, 11:16 PM   #12
Master Electrician
yup, you may want to clip it once or twice as it'll want to "float"
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
plummen (09-19-2012)
Converting switched outlet to unswitched.. Blivit Electrical 8 07-11-2011 08:07 AM
Switched outlet and running new wire matt151617 Electrical 7 07-03-2011 11:55 AM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
Exterior 50 Amp RV Outlet theatretch85 Electrical 9 11-05-2009 12:07 AM
