Running Outdoor Cable From House To Detached Shed Above Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 09:07 PM   #1
Rewards Points: 1,062
Question
running outdoor cable from house to detached shed above ground
i have buried conduit to my detached shed but need to wait to upgrade my meter with more amperage and circuits before i can run 50A to it. but in the meantime, i was gonna have a makeshift temporary solution for just lighting by running outdoor cable from the deck floodlight box to the shed, which would be about 10 ft in length and some 8 ft above the deck. i was gonna nix the makeshift solution once i get a new meter and run the wire underground through the conduit. but was wondering if there are implication to doing it this way. i was only gonna have one light and maybe one outlet in the shed running on it (as to avoid tripping the circuit with too much amperage). primarily, i was concerned about the grounding issues since the cable is leaving the building where the panel is.
BTW, i have a grounding rod buried next to the shed as well for when i do run the 50A circuit to feed the shed subpanel. dunno if that might help the temporary solution somehow.
thanks
Old 11-18-2010, 09:10 PM   #2
Run the wire for 50a to the shed
Pigtail #12 on it & connect it to a 20a breaker
Upgrade to 50a & sub later on
The Following User Says Thank You to Scuba_Dave For This Useful Post:
amakarevic (11-19-2010)
Old 11-19-2010, 03:16 PM   #3
Rewards Points: 150
Run the 50A. Install the subpanel. Put a 20A circuit in it.
Having a 50A subpanel there does not mean it will be pulling 50A. Especially if you're already planning a service upgrade in the near future, there is no reason to wire the same shed twice.
emolatur is offline   Reply With Quote
Detached garage ground wire to house EMT? johnd393 Electrical 15 09-22-2010 10:15 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Definition of Detached house vinny General DIY Discussions 2 06-01-2009 01:08 PM
Detached shed/shop rewire gtmatt Electrical 7 05-24-2008 10:40 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
