Running NM Through Studs - Electrical - DIY Chatroom Home Improvement Forum
Old 06-20-2011, 07:47 AM   #1
Just call me Andrew
Rewards Points: 1,020
Running NM through studs
Is there a standard size bored hole I should use when running 12/3 (and some 12/2) through a series of 2x4 studs? Or is it just a judgement call?
If I put the hole dead center (more than 1.25" from each side) I do not need nail plates, correct?
Do I need to secure the cable to the wall with a staple before it enters a receptacle box? Or does the bored hole that will be just above the box count?
Thanks!
Andrew
secutanudu is offline   Reply With Quote
Old 06-20-2011, 07:56 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
I use a 3/4" bit.
Nail plates not needed if center of stud.
And cable going into a box needs to be stapled.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
secutanudu (06-20-2011)
Running wire to box between two studs Eclipse99 Electrical 6 03-22-2010 06:20 PM
How to repair rotted joists and studs? Snav Building & Construction 5 02-24-2010 11:35 PM
Can I use Microlam for Jack Studs? (Enlarging Door Opening) Kevin8565 Carpentry 7 04-30-2008 01:27 PM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 11:57 AM
Securing stacks between studs... J187 HVAC 1 11-11-2007 06:39 PM
