Running NM Cable Through Studs? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2012, 09:02 PM   #1
Rewards Points: 31
Question
Running NM cable through studs?
First off, go easy on me...I'm not an electrician :/
I need to run around six feet of Romex/NM cable inside a wall, so Iíll have to somehow pass it through around 4 studs.
I know I can drill a hole in each stud and thread the cable through, but my question is: can I instead just chisel out a notch at the end of each stud to pass it through?? Iíll be dealing with old plaster/lath, and this would simply be a lot easier than having to clear out enough space to get a right-angle drill in, etc., etc.
Yes, Iíd cover the end of each stud with a nail plate, but in the end, the cable will admittedly be running right up against the inside of the wall (as opposed to more in the center if I drilled holes), so I didnít know if this was safe/permitted by code?
Thanks for your help.
RinSF is offline   Reply With Quote
Old 04-01-2012, 09:10 PM   #2
joed's Avatar
Rewards Points: 13,748
You would need to put a metal plate over the cable to protect it from nails and screws.
Can you go down into the basement or up into the attic and across then back down? The holes in this picture are drilled but this is an example of nail plates.
Old 04-01-2012, 09:12 PM   #3
Rewards Points: 6,652
As long as you use the nail plates, but it still does not protect the wire that is against the Lathe, if someone was to start driving a nail, drill, or put in a screw, which will and can possibly go through the Romex. Your best bet is to drill the holes in the middle of the stud, then patch with gypsum board, and if needed, use Plywood as shims to shim out the gypsum to make it even with the plaster and lathe for finishing.
Old 04-01-2012, 09:48 PM   #4
Ravenworks's Avatar
You could always run it under the baseboards
Ravenworks is offline   Reply With Quote
Old 04-01-2012, 09:58 PM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You only need a small gap wide enough to get the drill bit in there and drill at an angle. I use a flexible extension for this. Get it started then straighten it out and drill all the way through.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-01-2012, 10:14 PM   #6
"So I Re-Wired It"
MisterZ's Avatar
a right-angle drill attachment works well too
MisterZ is offline   Reply With Quote
Old 04-01-2012, 10:24 PM   #7
Rewards Points: 31
Thanks for the help so far. To note:
- There is no attic/basement...I only have this wall to work with.
- I know I can drill things, my post was really to find out if notching out the end and using a nail patch is an okay way to do this and acceptable per code. (Drilling would mean tearing out more wall, and also, I don't own any right-angle drills or attachments so I'd have to go buy more things.)
I guess one option would be to run the length a few inches from the ceiling...these are wall sconces after all, so they're already pretty close to the top. That way, the cable would be out of the way (i.e., it's unlikely anyone would be nailing/drilling that close to the ceiling).
Old 04-01-2012, 10:26 PM   #8
rrolleston's Avatar
Only problem with notching is it leaves the wire too close to the wall.
Old 04-01-2012, 11:57 PM   #9
Rewards Points: 14,312
And weaken the studs.
Old 04-02-2012, 05:54 AM   #10
Rewards Points: 2,516
So take 6 feet of romex, form it into a circle and run around it.
Sorry couldnt help that.
Anyway I think like greg and rrolleston pointed out even though the nailing plate would protect the cable at the stud, what would protect it along the lathe?
hammerlane is offline   Reply With Quote
Old 04-02-2012, 06:10 AM   #11
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
it would be behind the lathe...inside the wall
Old 04-02-2012, 07:15 AM   #12
And how thick is lathe??
Old 04-02-2012, 07:27 AM   #13
Licensed Pro
Notching the studs in a retrofit situation is fine. Just use nail plates at each notch and don't notch more than about a third of the depth of the stud.
Old 04-02-2012, 08:55 AM   #14
rrolleston's Avatar
I would never notch framing it weakens it much more than drilling a hole.
Old 04-02-2012, 11:38 AM   #15
Rewards Points: 31
My initial fear was whether it was unsafe having the cable running right along the inside of the wall if I notched things, but I didn’t realize that notching weakens studs more than drilling.
Would notching really be that much of a problem though? I’m only notching out enough to fit one 14/2 cable through…so I wouldn’t be cutting out very much. Also, it’s an old 1916 home…so the studs are truly 2” x 4 in size (as opposed to 1.5” x 3.5”, or whatever modern lumber is).
Running cable along bottom of rafters Jaxx Electrical 3 03-11-2012 06:44 PM
Running Network Cable in preexisting home Nate8727 Building & Construction 19 06-30-2011 02:27 PM
Running NM through studs secutanudu Electrical 1 06-20-2011 06:56 AM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 08:39 AM
Running wire to box between two studs Eclipse99 Electrical 6 03-22-2010 05:20 PM
