Running New Timed Line Under House - Electrical - DIY Chatroom Home Improvement Forum
Old 06-27-2015, 11:46 AM   #1
Rewards Points: 80
Running new timed line under house
Am i ok to run a new Romex line under my house to where I need it? Or do I need conduit or a different type of wire?
How do I secure the wire to the foundation in the crawl space?
bhollehday is offline   Reply With Quote
Old 06-27-2015, 02:46 PM   #2
Electron Plumber
Rewards Points: 1,604
Cables with less than three #8 conductors or any cable smaller than #8 need to be installed in holes drilled through the joists or on running boards nailed to the joists. Staples are the standard method.
Old 06-27-2015, 05:18 PM   #3
Rewards Points: 80
8 gauge? We're using 14 gauge so just staple to the joists and drill hole through the cross joists then correct?
Help with main supply line to house jeffnc Plumbing 2 04-14-2014 08:35 AM
Running 12/2 New Line thechalker Electrical 4 12-14-2012 11:10 PM
Relocating House Main Supply Line Entry setzerr Plumbing 0 07-15-2011 06:44 PM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
Running pex from the meter to the house, but what about above ground? chayce Plumbing 4 11-09-2010 06:36 AM
