-   -   Running new oulet for fridge (http://www.diychatroom.com/f18/running-new-oulet-fridge-135609/)
bowanna03 03-01-2012 07:23 PM
I am moving our fridge into our old pantry and need to install an outlet. I am thinking about adding a new 20 a breaker, runing the wire to a new outlet and installing it in the wall in the old pantry area. Couple of questions I have. One, what is the best way to find where to drill in the basement to run the line up through the floor to the wall? Two, should I open the wall more and put in an electrical box that attaches to the stud or use a remodel box? Anyone help on installing a breaker also and what is the best wire to use also?
rrolleston 03-01-2012 07:28 PM
Usually doing a lot of measuring helps and looking at what is above the basement heater vents gas lines water lines drain pipes.
Jim Port 03-01-2012 07:52 PM
There are remodel boxes that screw to the studs. Look for Smartbox.
Along with measuring from know items you can drill a small hole at the baseboard into the basement. This will show the face of the wall, now just measure about 2" back and you should be in the wall cavity.
bowanna03 03-01-2012 07:56 PM
Where can you get the smartboxes from?
Thanks for the info on finding the spot to drill for
Missouri Bound 03-01-2012 08:09 PM
Jim Port gave the best advice. If you have the ability to remove the baseboard at that location you could drill right along the wall, then put the baseboard back after you determine the location...if not, follow Jim's advice.:thumbsup:
ben's plumbing 03-01-2012 08:13 PM
jim has the low down on this install take your time measure,measure before to cut measure again...smartbox...awesome....:yes:
rrolleston 03-01-2012 08:43 PM
A hole just small enough to stick a colored wire through that can be seen in the basement. Also mark how far you are from framing in the wall. You don't want to drill into a 2x4 or hit a framing nail.
I just put our fridge on it's own circuit because we had a gfci trip once and almost cause a mess.
bobelectric 03-02-2012 03:36 AM
Moving out of kitchen might get you into arc fault breaker required circuits.
Ravenworks 03-02-2012 08:49 AM
Before I cut the hole for a work box I have found a quick way to find obstructions in walls.
What I have found to be a sure fire way test this is to take a piece of wire and bend a 90 in it. Drill a small hole in wall where you want the box and spin the wire,if you hit a stud then you know which way you need to adjust the hole.
I learned this the first time I cut a hole and landed in the middle of a stud,I know there are other ways such a measuring and stud finders but I am lazy.
Hardway 03-02-2012 08:54 AM
you stole my thunder!:thumbup:
Hardway 03-02-2012 08:58 AM
I use a square hole saw in my drill, it makes a perfect square hole every time.:laughing:
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
JRigby 03-02-2012 09:18 AM
When you cut out the hole for the new box, always make the horizontal cut first. This way if you hit a stud you can adjust. As far as where to drill your hole to the basement, the other posts were right on. I would like to add that somtimes you can look at the structure underneath and determine where the wall is based on the framing.
rrolleston 03-02-2012 10:03 AM
Don't forget to look for treasure inside the wall.:laughing:
