Old 06-08-2014, 02:47 PM   #1
Share |
running new EMT conduits from the panel
Going to be running new EMT conduits from the panel to the kitchen.
Don't see a big deal with that...however, I am wondering how to feed conductors into or from the panel. As I pull the conductors through, I don't want any loose wire or metal fishtape to accidentally bounce into anything live I'm the panel box. I can turn the main breakers off but still the big service wires and where they screw into.
What are the safety procedure to follow? Tape all conductor ends I am pulling...do I tape a garbage bag over stuff inside the panel? Do I connect an elbow to extend the line outward of the panel box? Do I get my in-laws to do this?
miamicuse is offline   Reply With Quote
Old 06-08-2014, 08:50 PM   #2
Use fiberglass fish tape. Pull wires to the panel with spools at far end. That way you see wires emerge into panel and you can pull a few more feet for hookups. Have a helper feed wires into the far box so no kinks or tangles.
curiousB is offline   Reply With Quote
Old 06-10-2014, 06:28 AM   #3
Licensed Electrician
k_buz's Avatar
Pulling a fishtape (much less metal) into a live panel is bad practice. It is just asking for problems. Feed the wire from the panel side of the run.
Or...
Install a JBox near the panel, pull the majority of the run to the JBox. Then you can push the wire (only) into the panel.
Old 06-10-2014, 07:29 AM   #4
If your "ascared" pulling into or from the panel, you can put cardboard here and/or there.
just a thought
ritelec is offline   Reply With Quote
power new 200amp panel as temporary subpanel from existing 100amp main panel CapeCod153 Electrical 4 03-21-2013 08:31 PM
changing to 200 amp service mbaldwin Electrical 3 03-29-2012 08:00 AM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Help/Suggestions Running Cat5e Acroos Room To New Panel darveaux Electrical 6 02-28-2011 02:12 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 12:43 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
