Running New Dryer Wire...but Dryer Is Three Plug Currently. - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2009, 10:03 AM   #1
Rewards Points: 406
Running new dryer wire...but dryer is three plug currently.
So since I'm moving the dryer I'm running a new line from the panel which will be 10/3 but my current dryer is a three plug dryer so I'm going to have to hook up a three-plug receptacle until I get a new dryer. Will this work fine for now, do I just ground the green wire until it's needed?
RyanD is offline   Reply With Quote
Old 08-07-2009, 10:23 AM   #2
Licensed Pro
Just replace the cord on the dryer with a four-prong cord. Remove the jumper between the center (neutral) connector and the dryer frame, connect the red and black to the outside terminals, the white to the middle, and the green to the dryer frame.
Old 08-07-2009, 10:24 AM   #3
Why not just replace the dryer cord?
jerryh3 is offline   Reply With Quote
Old 08-07-2009, 10:25 AM   #4
Rewards Points: 406
Will the dryer accept that?
Old 08-07-2009, 10:32 AM   #5
It should. What's the model number?
Old 08-07-2009, 10:33 AM   #6
Rewards Points: 406
No idea, it was there when we moved in. It appears to be pretty old though.
Old 08-07-2009, 10:41 AM   #7
Unplug the dryer and take off the connection plate. If you see four screw terminals with a bonding strap between the green and white follow the instructions in post #2.
Old 08-07-2009, 02:33 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Your 10/3 G for the new circuit will need a 4 wire power cord on the dryer and 14-30 receptacle. As mentioned in previous posts... covert the dryer to 4 wire then use that same 4 wire power cord on your new dryer when you get it. All electric dryers have the ability to be 3 or 4 wire. New installations require a 4 wire branch circuit. In 3 wire configurations the ground wire is not present so they bond the metal frame of the dryer to the neutral and it does double duty as ground and neutral. This is almost always done with a bonding jumper of some sort at the dryers electrical terminal block. There are a few safety issues when bonding the dryer frame to the neutral since it is a current carrying wire. So all new construction requires you to run a 4 wire branch circuit with a separate ground wire to avoid this bonding of neutral and ground like you have with 3 wire dryers.
I'll post a drawing of what it is you will be doing.........
Running new dryer wire...but dryer is three plug currently.-4-wire-dryer-option-1.jpg
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Running Electical plug behind wall burdman Electrical 2 04-20-2007 10:15 AM
Running speaker wire parallel to electrical wire spyguy Electrical 3 02-21-2007 02:10 PM
Open beam ceiling and running wire... Alan Electrical 2 12-10-2006 09:14 PM
running wire questions jude Electrical 4 12-01-2006 12:41 AM
