-   -   Running new dryer wire...but dryer is three plug currently. (http://www.diychatroom.com/f18/running-new-dryer-wire-but-dryer-three-plug-currently-50426/)
RyanD 08-07-2009 10:03 AM
So since I'm moving the dryer I'm running a new line from the panel which will be 10/3 but my current dryer is a three plug dryer so I'm going to have to hook up a three-plug receptacle until I get a new dryer. Will this work fine for now, do I just ground the green wire until it's needed?
HouseHelper 08-07-2009 10:23 AM
Just replace the cord on the dryer with a four-prong cord. Remove the jumper between the center (neutral) connector and the dryer frame, connect the red and black to the outside terminals, the white to the middle, and the green to the dryer frame.
jerryh3 08-07-2009 10:24 AM
Why not just replace the dryer cord?
RyanD 08-07-2009 10:25 AM
Will the dryer accept that?
jerryh3 08-07-2009 10:32 AM
It should. What's the model number?
RyanD 08-07-2009 10:33 AM
No idea, it was there when we moved in. It appears to be pretty old though.
jerryh3 08-07-2009 10:41 AM
Unplug the dryer and take off the connection plate. If you see four screw terminals with a bonding strap between the green and white follow the instructions in post #2.
Stubbie 08-07-2009 02:33 PM
1 Attachment(s)
Your 10/3 G for the new circuit will need a 4 wire power cord on the dryer and 14-30 receptacle. As mentioned in previous posts... covert the dryer to 4 wire then use that same 4 wire power cord on your new dryer when you get it. All electric dryers have the ability to be 3 or 4 wire. New installations require a 4 wire branch circuit. In 3 wire configurations the ground wire is not present so they bond the metal frame of the dryer to the neutral and it does double duty as ground and neutral. This is almost always done with a bonding jumper of some sort at the dryers electrical terminal block. There are a few safety issues when bonding the dryer frame to the neutral since it is a current carrying wire. So all new construction requires you to run a 4 wire branch circuit with a separate ground wire to avoid this bonding of neutral and ground like you have with 3 wire dryers.
I'll post a drawing of what it is you will be doing.........
