Running New Curcuit To Outdoor Application? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2009, 09:16 PM   #1
Running new curcuit to outdoor application?
My wife and I would like to put water feature, a waterfall wth a small pond, on the side of our house. I know that at a minimum I will need an outlet for the pump and that I would like to have some lights in the set up for viewing at night.
As I'm planning this, my thought was that this could be done with a new 20amp circuit however it appears the main panel is full, no empty slots.
Would this require the installation of a sub panel or does anyone have some diferent thoughts or experience?
Bigman610 is offline   Reply With Quote
Old 01-21-2009, 10:05 PM   #2
Electrician
ctsmiths's Avatar
Rewards Points: 150
Could use some minis in place of a regular breaker. I dont really like them but its a thought.
ctsmiths is offline   Reply With Quote
Old 01-21-2009, 11:39 PM   #3
DIYer
If you panel allows them that is. You can't use a twin breaker in a newer 40 slot panel.
You could extend an existing lightly loaded circuit, but you need to pick one that is not a special purpose one defined in the NEC.
Gigs is offline   Reply With Quote
Old 01-22-2009, 05:23 AM   #4
Remodeling Contractor
At the panel cover you should find the number of circuits it allows. might sa something like 30/42 meaning 30 full size but 6 spaces can be used for minis. These are breakers that allow two circuits for one 1" space. But you may also consider using a 12/3 UF cable to the pond, so the lights can be controlled b a switch and the pond is separate.
Old 01-22-2009, 07:32 AM   #5
Thank you for the thoughts. I like Bob's suggestion to run 12/3 and have the lights on a switch. I looked at the panel again and can't pick out anything showing the number of circuits allowed. I'm going to put some feelers out and get a few quotes to have the project done correctly, assuming the damage "$$" won't be too bad. Thanks again.
constant running water sound gmk2008 Plumbing 9 11-11-2008 08:22 PM
Sump pump running as much as 20 times per day Shpigford Plumbing 7 06-23-2008 09:33 AM
Freedom 90 furnance not running reliably from generator jrielsky HVAC 6 02-12-2008 01:48 PM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
Running a generator for power outages tropic home Electrical 5 12-04-2006 08:22 PM
