-   -   Running a new circuit for ceiling fixtures through existing walls/ceilings (http://www.diychatroom.com/f18/running-new-circuit-ceiling-fixtures-through-existing-walls-ceilings-20243/)
beezlebub03 04-23-2008 01:40 AM
I'm a competent DIYer and a quick study, but mostly a newbie when it comes to electrical stuff. I've got two projects for which I got astronomical estimates from electricians; I'd like to give them a go myself to save a few shekels.
I need to run a fresh circuit through an unfinished section of basement, up through a wall, into the ceiling above the main floor of my home to service a ceiling fan and a half dozen remodel can lights. The line to my ceiling fan will need to run for about 30 feet inside the joist bay before taking a left turn through a joist. Is it okay to leave the electrical wire resting on top of the lathe and plaster ceiling or must I pop holes in the ceiling every few feet to staple the wire to the joists?
The ceiling fan will go in where there's currently a light fixture serviced by ungrounded knob and tube wiring (house was built in '28). I intend to junk the old ceiling fixture and disconnect the knob and tube to it before running modern wire to the ceiling fan. Once I do this, I will still have a live knob and tube circuit going to the wall switch that controlled the old light fixture. I can't fully decommission that knob and tube line since it still powers a couple of wall outlets. Can I simply cap the knob and tube wiring that led to the old light fixture's wall switch, wrap it with electrical tape and leave it inside the wall? I don't see how else to deal with it.
Thanks in advance for the help any of you can offer!
joed 04-23-2008 08:28 AM
It is OK to leave wire loose in an existing wall/ceiling cavity. No need to pop holes to staple.
You can not leave live wires inside the wall capped. They must be in a box with a cover that is accessible.
beezlebub03 04-23-2008 12:51 PM
Joed, thanks a million. Is it okay to cap the knob and tube wires and leave them unattached within the box to the switch? The switch, of course, will be connected to my new wiring. I wondered if this was okay since the capped, disconnected old wires and the new wires will all be behind a switch plate.
Cyndi 04-23-2008 01:08 PM
Beezlebub03-
Thanks for the detailed question.
Joed-
Thanks for the clear answer.
This is the kind of informtion newbies like me appreciate!!!
joed 04-23-2008 03:43 PM
I think you are fine to leave the old wires in the same box as the new ones.
The best solution is to find the other end of the wrres and cut them of at the source. But that is very often not possible with knob and tube.
jrclen 04-23-2008 05:22 PM
There is no problem having the old wires (live or not) terminated in wire nuts in the same box with the switch and the new wiring.
beezlebub03 04-23-2008 08:49 PM
You guys rock. Thanks.
