Running New Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2009, 08:55 AM   #1
Running New Circuit
Hi guys. I have a simple quick question for you.
I am running a new circuit to run some aquarium stuff. I have a nice long roll of 12-2 laying around, so that is what I will run. My question is, what size breaker can I safely use for a 100' run of 12-2? 30A?
Thanks,
Jason
jasoncw is offline   Reply With Quote
Old 02-15-2009, 08:59 AM   #2
Electrician
Rewards Points: 778
#12 is good for 20A so nothing bigger then a 20A breaker, you could use a 15A breaker but that is kind of waste for the wire you have.
Use a 20A breaker and some T-slot plugs.
darren is offline   Reply With Quote
Old 02-15-2009, 09:02 AM   #3
100'? I thought you had the aqaurium not the neighbour
Chemist1961 is offline   Reply With Quote
Old 02-15-2009, 09:02 AM   #4
Rewards Points: 1,192
Where is your N.E.C. codebook????????
bobelectric is offline   Reply With Quote
Old 02-15-2009, 09:02 AM   #5
As long as he uses a duplex outlet he can use a 15A instead of the t slot 20A.
Plumbvoltage is online now   Reply With Quote
Old 02-15-2009, 09:11 AM   #6
Thanks, guys. I appreciate the help.
Box is in the basement in the opposite corner of the house.
Um, this is a DIY site, right? I'm not an electrician.
Old 02-15-2009, 03:16 PM   #7
"Aquarium" ....in the basement.....
I amazed at how many people have "aquarium" related questions
220/221 is offline   Reply With Quote
Old 02-15-2009, 03:28 PM   #8
Make sure its GFCI outlet
For my 240g reef setup I run power to several outlets, each one is wired to hot feed & each one is a GFCI outlet. That way if something kicks out the GFCI outlet not everything on the circuit dies
Pump & one heater is one circuit
1 heater on another circuit
Another recirc pump is on another circuit
Lights are on another circuit
Old 02-15-2009, 03:34 PM   #9
Electrician
ctsmiths's Avatar
Rewards Points: 150
Thanks,
Jason
Are you using all 100 feet, and what is the load in amps that youll be putting on the line? Reason I ask is you may want to take voltage drop into count.
ctsmiths is offline   Reply With Quote
Old 02-15-2009, 05:03 PM   #10
For my 240g reefer setup I run power to several outlets, each one is wired to hot feed & each one is a GFCI outlet.
Old 02-16-2009, 01:06 PM   #11
I plan on running two circuits (both using 12-2). And yes, of course I was planning on GFCI outlets. Thanks for the input. Good advice.
Old 02-16-2009, 01:12 PM   #12
It will end up being closer to 75'. The main things I am concerned about keeping on a separate circuit is the lighting (~4-5A) and pump (~4A). There will be others, but I won't be pushing 20A per circuit.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
