Running New 2nd Floor Wiring On *exterior* Of Our Home? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2008, 10:09 AM   #1
drh
Running new 2nd floor wiring on *exterior* of our home?
Hi guys,
Quick question to confirm my sanity here - we're in the process of pricing out some knob and tube replacement in our home, and one electrician we had pricing the job suggested something peculiar.
He suggested that rather than fishing wiring up through walls, he prefers to bore holes in the exterior wall and run the wiring to the second floor on the OUTSIDE of the home, boring back in on the second level.
This seems ludicrous to me, to have electrical wiring runs on either side of our home, on the exterior. Not to mention an unsightly mess.
Was I correct in thanking this guy for his time, and quickly showing him the door? I mean, would something like even pass code?
Dan
drh is offline   Reply With Quote
Old 02-15-2008, 10:16 AM   #2
Licensed Pro
It might pass code, but it shows the electrician is lazy and not concerned with how his work may look. The only time such a scenario should be considered is if the structure is not wood framed and there are no cavities to fish the wire through.
Old 02-15-2008, 05:31 PM   #3
Res Ipsa Loquitur
This breaks the "insulation envelope" that is so necessary in this day of high utilities- looks unsightly and should only be used as a very last resort after all other possibilities have been exhausted!
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 02-15-2008, 07:29 PM   #4
joed's Avatar
Rewards Points: 11,500
The wire would need to be outdoor rated for wet location.
Old 02-15-2008, 10:44 PM   #5
Hopefully the guy is suggesting the wire be run through conduit (like perhaps conduit used for service entrance... the 2-3" stuff).
HooKooDooKu is offline   Reply With Quote
Old 02-15-2008, 10:54 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
It would not matter. If you run wire wire outside in conduit, it must be rated for a wet location
Old 02-15-2008, 11:26 PM   #7
Union Electrician
goose134's Avatar
Many times it is easier to run a single piece of conduit to the attic with a few circuits and branch off of them from above. It's what I did at my friend's place to replace his K&T. Depending on the amount of circuits, you wouldn't need better than a 3/4". Incidently, MOST THHN wire is also THWN rated. You wouldn't need to run the romex through the conduit. That would just be a waste.
goose134 is offline   Reply With Quote
Old 02-16-2008, 12:27 AM   #8
hms
Remodeling contractor
find someone to do it the right way and more importantly to your satisfaction.
hms is offline   Reply With Quote
Old 02-16-2008, 01:15 PM   #9
remodeling pro
It is not uncommon to run ONE conduit up to the second level or completly up to the attic, and use it to pull feeder lines through, then wire the upper story from the attic above. This is much more economical than fishing 10 or 15 wires up throught two story walls, and will not be visually objectionable if run neatly. But if he was talking about running an exterior conduit to each device he needed to feed, you were indeed best served by sending him down the street.
troubleseeker is offline   Reply With Quote
Old 02-16-2008, 03:15 PM   #10
You CAN run (the proper type of) cable on the outside of your house.....but I wouldn't do it.
Asthetics are important to me.
220/221 is offline   Reply With Quote
Old 02-16-2008, 05:41 PM   #11
Power Gen/RS Engineer
Rewards Points: 566
I agree with Goose and 220.
Where I live, I've seen several instances of conduit being run up to the attic on the exterior of the house in which several circuits are pulled that eventually fan out to various things on the second (or top) floor. Provided that the correct materials are used, there is nothing wrong with this. If this was his approach then I wouldn't necesarily say that it was bad. On the other hand, if he's thinking of running several conduits, then I'd agree that he's probably not the best.
As 220 mentioned though, aesthetics are a big issue with this type of approach, especially if this is your house. You'd be the ultimate judge of whether it'd be unsightly.
Take care,
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 02-16-2008, 05:52 PM   #12
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If it came down to it, I believe repairing a wall somewhere inside the building if that is what it took to run a large conduit for all the branch circuits up to the attic, rather than running it on the outside.
Don;t forget to derate the conductors!!!!!!
Old 02-16-2008, 07:27 PM   #13
drh
Thanks to everyone who responded. This is precisely the type of forum and exchange that helps us newbies make the right decision - and for that I am truly grateful.
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
miller mobile home furnace wont keep running jb9270 HVAC 4 01-30-2007 11:12 AM
