Running New 240 For Range - Electrical - DIY Chatroom Home Improvement Forum
Old 04-15-2010, 02:05 PM   #1
Running new 240 for range
I've been reading through some posts and have gotten lost in them at some point so here goes mine:
I have a new range coming Saturday. The old was a gas range, replacing with electric.
I've ran 6/3 from the box to the outlet. The outlet I have no problem with figuring out, the box however is the old style fuse box.
There is an open 240 line available for me. I know I run the Red and Black to the breaker/fuse that is open (240). But where the heck does the White and bare copper wire go?
In the fuse box I see all the whites run to a leg, but there is not another separate leg for the ground. They are all connected together. Is this against code or can I run the white/ground to the same leg?
Thank you in advance, and I can also post a picture if needed.
jhall555 is offline   Reply With Quote
Old 04-15-2010, 02:45 PM   #2
Electrician
Rewards Points: 778
White called the neutral can be on the same bar as the ground but not under the same screw. This only applies if it is the first panel in your house and the neautral and ground are bonded together which sounds like your case.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
jhall555 (04-15-2010)
Old 04-15-2010, 03:13 PM   #3
So the neutral and ground to the same block, just not under the same screw. And what if there are no extra screws? They must make an extension of some sort??
Old 04-15-2010, 05:20 PM   #4
Master Electrician
Rewards Points: 3,756
Someone should investigate whether your electrical service has the capacity for the increased load of an electric range.
brric is offline   Reply With Quote
Old 04-15-2010, 07:08 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,876
For an old fuse box I would post a picture of it so we can see where the connections are.
Old 04-15-2010, 08:12 PM   #6
Put some grounds under the same screw.
What was meant was that you cant land a neutral and ground under the same screw.
voltech is offline   Reply With Quote
Old 04-15-2010, 08:29 PM   #7
Exclamation
It probably has. (I agree. It should be checked out by someone qualified.) But the important point is (Assuming that it does have the capacity for a 240v. range.), that the 240v. circuit should be connected to a 2-pole (cartridge) fuse socket. The requirement for that is because the 240v. circuit must be disabled completely. Otherwise, there could be feedback from the side that is live to the other, disabled side through the appliance.!
spark plug is offline   Reply With Quote
Old 04-15-2010, 09:01 PM   #8
On most panels 2 grounds of the same gauge can go under the same screw
Neutrals only 1 per screw
They do make additional ground/neutral bars that can be added
I added one to my panel
Old 04-19-2010, 04:29 PM   #9
Thank you all for the replies.
I ended up doing the "big swap"
Went from the old fuses to breakers. All is up and running now!
Thank you again.
Toilet running water leaking issue? mikehende Plumbing 16 06-01-2009 11:07 AM
constant running water sound gmk2008 Plumbing 9 11-11-2008 09:22 PM
Sump pump running as much as 20 times per day Shpigford Plumbing 7 06-23-2008 10:33 AM
Freedom 90 furnance not running reliably from generator jrielsky HVAC 6 02-12-2008 02:48 PM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 08:03 AM
