Running A New 220 Service Underground - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2009, 05:04 PM   #1
I bought a existing house with a large out-building which used to have 220 service running underground. The previous homeowner damage the underground line and I cannot find where it's damaged plus the wire has been pulled from one end. I need to replace it. It's about 175' from the service in the house and it has a 100 amp service panel in the builidng. What gauge and type of wire do I need? I plan on running conduit. The previous homeowner had used 2 insulated wires which read AWG2 Compact AL Triple E Alloy and one copper ground. Is this the correct wire to run. Any help would be greatly appreciated.
toddthor is offline   Reply With Quote
Old 08-27-2009, 05:42 PM   #2
Electrical Contractor
kbsparky's Avatar
If you want to start over, then please note that nowadays you will need 4 conductors between buildings.
#2 AL is good for 90 Amps. If you want a full 100 Amps, then use #3 copper wires, or #1 Aluminum for your hot feeds.
We would use (2) #3 copper THWN; (1) #4 copper white for the neutral, and (1) #8 green for the equipment grounding conductor. They will fit in a 1" PVC conduit, but for a run that long, you might want to consider using a 1" conduit.
IF you prefer Aluminum, we would use (2) #1 XHHW for the hots, (1) #2 for the neutral, and (1) #4 for the ground. I'd recommend a 2" conduit for that run, due to the distance involved.
In either case, you will have to utilize a ground rod or other approved means of grounding at the remote building.
-KB
Old 08-27-2009, 05:54 PM   #3
Rewards Points: 1,016
Do you really need 100 amps in the out building - and is it currently being fed by a 100 amp breaker in the main panel? Suggest you start with a load calculation. If you feed it with a smaller breaker in the main panel, say a 60 amp, then you use a smaller wire size.
Old 08-27-2009, 08:46 PM   #4
The building is about 3000 sf. It's heated and air conditioned when power is hooked to it. I want to have adequate power when I utilized the building in the future. Everything is in place expect for the main power line.
Old 08-27-2009, 08:52 PM   #5
kbsparky
Thanks for the information. I planned on using 2" conduit to make things easier. Can I pull all the wires at once? I am going to have to use a couple of 90 degree elbows. Will that be a problem? I am also running 1" conduit for telephone and cat5e.
Old 08-27-2009, 08:53 PM   #6
1 1/2" or 2" pvc, 18" deep with three #2's (nobody stocks # 3 here) and a #8 green ground.
220/221 is offline   Reply With Quote
Old 08-27-2009, 10:16 PM   #7
Rewards Points: 502
What he said.
I ran 1 1/2" conduit for mine, about 150' with two 90s. I pulled 3 #2 cu and 1 #6 cu all at once. (I cheated and used my Gator to pull them, but it wasn't too bad.)
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 08-27-2009, 11:48 PM   #8
kbsparky's Avatar
Originally Posted by toddthor View Post
kbsparky
Yes, you pull the wires in all at the same time. Be sure to use only long sweep electrical 90 elbows on those conduits. NEVER use plumbing elbows!
You are allowed a maximum of (4)-90 elbows on any one run of conduit.
Installing a separate 1" conduit for communication makes perfect sense.
A tip for you: Install the complete empty conduit system first. GLUE ALL THE JOINTS! (You'd be surprised at how many DIY's fail to do this).
Then take some light weight string, and tie a baggie on one end. On the other end, use a powerful shop vac and suck the string thru. Pull a larger rope thru with the string, and then use that for pulling your wires.
On longer runs, it helps to use some pulling lube ( I call it "slime") to make the wire pull easier.
-KB
Old 01-19-2011, 10:30 AM   #9
I had a 100 year old house moved on to land. It needed to be redone, no indoor plumbing. This is my 7 house to redo, so I have done most of the work that is needed, but i have run into damage 4x6-14 beams, I have been able to replace 5 of them, I have 3 left to replace, the house is 28x42 in size, One 28' foot side needs to be replace, the 2 4x6 has ant damage/water,the 2x6 that set on top of the 4x6 has been cut into several section the load bearing wall is the center wall that runs down the center 42' long and the other 42' sides, that I can tell, on the 28' side 14' is a wall,14' is a porch, the wall section is what is needed to be jacked up,but I can not tell if this is load bearing
i
bedwell is offline   Reply With Quote
Old 01-19-2011, 11:12 AM   #10
Just call me Andrew
Rewards Points: 1,020
You can also run the rope/string through the conduit as you glue. Do NOT do this with the conductors, the pvc cement can eat through the insulation.
Andrew
secutanudu is offline   Reply With Quote
Old 01-20-2011, 01:10 AM   #11
Scared Electrician
Saturday Cowboy's Avatar
I don't recommend this as your string will end up glued. Use the vac trick, or a fishtape
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-20-2011, 01:30 AM   #12
Just call me Andrew
I've done it, didn't have that issue.
Andrew
Old 01-20-2011, 06:59 AM   #13
Rewards Points: 1,214
Beginners luck.
COLDIRON is offline   Reply With Quote
Old 01-20-2011, 09:12 AM   #14
Wire lube.
{On longer runs, it helps to use some pulling lube ( I call it "slime") to make the wire pull easier.}
Is this the same thing that we call wire KY?
Bob
Hourglass52 is offline   Reply With Quote
Old 01-21-2011, 04:39 AM   #15
kbsparky's Avatar
I call it industrial strength K-Y ....
-KB
Running Service to Barn - 100 amp AndrewF Electrical 20 10-13-2014 09:21 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
running underground electrical, communication, and water Chavez Electrical 4 04-05-2009 01:45 PM
Copper wire sizing underground 185ft run 200A service DIYALLTHETIME Electrical 5 03-04-2009 09:22 PM
Running New 100 Amp Service ckladky Electrical 6 01-18-2009 01:57 PM
