Running New 100 Amp Service - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 10:49 PM   #1
Hello everyone,
hopefully some here can give me some solid advice.
My father & I have just built a 12X20 cabin in the woods.
We are now ready to take the electric to it.
We will be running it underground about 150 foot.
We are only going to run 110 on 100 amp service.
The codes state that we can use #4 or #6 THHN cable run in 1" PVC conduit.
What kind of wire do we need to run?
Do we only need something like a 4/3 UF?
Should we run single wire?
Also, any advice on the least expensive source for the wiring that we will need?
Thanks in advance for any replies.
Chris
ckladky is offline   Reply With Quote
Old 01-17-2009, 11:15 PM   #2
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
Since you're running 150' you should upsize the wire from #4cu to #2cu to account for voltage drop. Also check with your utility company to discuss your plans before you do anything. They may have their own requirement concerning the UG service as well as your plans for running only 120 volts and not 240. What's the point of doing that anyway?
Magnettica is offline   Reply With Quote
Old 01-17-2009, 11:26 PM   #3
Electrician
110 is a bad idea with voltage drop and all, why not just run a 4 wire and be done with it?
chris75 is offline   Reply With Quote
Old 01-17-2009, 11:29 PM   #4
I must also add that this is not really new service. We have a meter on the pole, which use to service our travel trailer. Now we just need to run from the meter to the cabin.
We are only running 120 as opposed to 240 because we will never use 220 in the cabin. At least that is our thinking.
We will only be running maybe 3 lightbulbs, and a small window A/C in the summer months.
How much more of an expense would it be to go 240?
Old 01-17-2009, 11:43 PM   #5
Rewards Points: 2,350
One more wire. You already have a double pole 100 A breaker. You already have a 120/240 V panel, so all you need is 4 wires, instead of three.
Old 01-18-2009, 12:40 PM   #6
Rewards Points: 82
Not enough to even notice. You still have to dig a trench. It would be foolish to run 120 volts to your cabin. Run a 4 wire circuit and put in a small sub panel in the structure. You will be glad you did.
Make sure you get a panel with a main breaker in it.
Old 01-18-2009, 01:57 PM   #7
Electrician
I cant believe I wrote 110 down...
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 09:14 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
How can I determine service amperage? dawho1 Electrical 13 04-07-2008 11:10 AM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
