Running Multiple Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 12:01 PM   #1
EIT/DIY'er
Running multiple wires
I have about 9 romex wires that I will need to run in one tight area (between two studs).
Two questions:
1) Is it OK for me to stack two wires and fasten them with the same staple to the studs?
2) Are there any products available to run and fasten these in a neat and orderly fashion? It will be a mix of 12 and 14 ga copper romex.
Lattimer is offline   Reply With Quote
Old 01-04-2012, 12:15 PM   #2
Licensed electrician
Rewards Points: 1,226
Try a 3M Stak-it. Gardner-Bender and Arlington also make the same thing.
Old 01-04-2012, 12:16 PM   #3
Julius793's Avatar
Well what I would suggest is nail in an empty staple and zip-tie all the wires to the staple but leave it nice and loose so there not tight around each other that way the heat can dissipate
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-04-2012, 12:16 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Coastal South Carolina
Old 01-04-2012, 12:18 PM   #5
EIT/DIY'er
Perfect. Thanks guys!
Old 01-04-2012, 12:41 PM   #6
A "Handy Husband"
rjniles's Avatar
An inspector might call you on it.
The Following User Says Thank You to rjniles For This Useful Post:
gregzoll (01-04-2012)
Old 01-04-2012, 12:49 PM   #7
Julius793's Avatar
Possible but they usually don't give me an issue.
running wires for wall heater Roundeye Electrical 2 09-17-2011 04:57 PM
Wires running into receptacle and switch boxes Abs777 Electrical 6 04-28-2010 01:50 PM
Running Wires in new construction bfan781 Electrical 6 03-13-2010 12:50 AM
Running wires across bottom of joists WaldenL Electrical 8 01-25-2009 04:00 PM
running wires in a conduit analogmusicman Electrical 50 07-13-2008 09:49 AM
