Running Low-voltage Wire And Data Cables In Parallel? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2013, 06:05 PM   #1
Running low-voltage wire and data cables in parallel?
Hey all,
I'm running a bundle of CAT6 data cables and coax cables (approx 7 cables) through my basement joists, and I wanted to know if it's OK to also route my doorbell wire and my ADT security system wire (20 gauge) within this bundle. My 12-2 electric wires are at least a foot away from all this to avoid interference, but would doorbell wire and the security wire also cause interference when run in parallel with CAT6 and quad-shield RG6 coax, or is that not an issue? Thanks.
bottlerockett is offline   Reply With Quote
Old 01-01-2013, 06:35 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Not an issue at all. Both the RG-6 and Cat6 have enough shielding and twisting to resist almost any interference, even most 120V (unless of course they are bundled and run long distances).
Carrier Cool & Heat 8.81 lbs Charge, comp. not running - fan is running justplumducky HVAC 23 07-27-2012 01:52 PM
Calculations for voltage drop of wire viper Electrical 12 05-26-2011 05:07 PM
Running low voltage & data wires acerunner Electrical 1 06-25-2010 12:43 PM
