Running Low Voltage & Data Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2010, 01:18 AM   #1
Running low voltage & data wires
What kind of code requirements are there with running low-voltage data lines like phone, cable, ethernet, security systems, speaker-wires, etc?
Aside from using proper wire type & gauge, is there a rating for in-wall use?
I believe low-voltage lines must be kept a certain distance from regular power lines. What is that distance?
acerunner is offline   Reply With Quote
Old 06-25-2010, 11:43 AM   #2
Totally screwed together
In order to avoid RF interference they should be shielded or kept 12" away from power lines. If they cross a line it should be at a 90 degree angle. Shielded means a regular wire run inside metal conduit, or that it comes with a foil shield built in.
The only rating is for Plenum use, which means inside air ducts. Everything else is fine for running inside walls.
xxPaulCPxx is offline   Reply With Quote
Running 120v and 230v Wires Next to Each Other tulsajeff Electrical 2 08-04-2009 10:33 PM
Running new doorbell wires after ripped old ones out? pcampbell Electrical 3 12-14-2008 11:31 AM
Running wires in a shower wall ? iMisspell Electrical 2 12-03-2008 10:31 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 09:38 AM
