Running Line Through Cinderblock... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-02-2011, 08:38 PM   #16
Rewards Points: 164
Not electrician or contractor reason for asking question on tis board for expert help and helpful info.
68MHJCs is offline   Reply With Quote
Old 10-03-2011, 08:24 AM   #17
Rewards Points: 760
Instead of boring a hole in the concrete, you run it up the side of the foundation in conduit and then use an LB (can find at a home store, a right angle fitting) you can bring the cable in through the wooden rim joist. It's a lot easier to drill and not nearly as thick.
AandPDan is offline   Reply With Quote
Old 10-03-2011, 10:43 AM   #18
My personal views (which may differ from others).
  1. Run conduit underground. It gives some protection to the wire and provides a method to easily replace/add wires if needed. Oversize the conduit (within reason) just in case you want to do something different in the future.
  2. 12" is not deep enough. We found that out when we had our stone driveway redone.
  3. The UF vs. THWN debate has those with strong feelings on both sides. I hate UF because it is hard to strip.
  4. I have run conduit through cement block using conduit. I aimed for the hollow portion of the block. I used a masonry hole saw. I drilled from both sides, inserted the conduit, and then filled the void in the block with expandable foam insulation (just as Tommy Silva did on Ask This Old House).
  5. We just had a new well installed. They ran the UF wire directly through the hole drilled in the poured cement wall. No conduit. Passed inspection.
brgmgb is offline   Reply With Quote
Old 10-03-2011, 11:58 AM   #19
Rewards Points: 6,652
Originally Posted by 68MHJCs View Post
There was already a line there but during the winter (problem) I hit the line with the snow thrower. Now every time I would turm the lampost on it would trip the curcuit.
How in the world did you take out a buried electrical line with a snowblower? Were you trenching with it, along with deciding that it was too boring to just stay on the drive and side-walks, so you decided to go four-wheeling around the yard?
running a second line to a shed Allspark Electrical 8 05-09-2011 04:21 PM
help running sewer line Hornnumb2 Plumbing 0 03-15-2011 07:33 PM
electric wires running along gas line gusyve Electrical 2 02-20-2011 01:02 PM
Do I need to prime my oil feed line? 1parkpointer HVAC 3 10-22-2009 06:52 PM
Running a natural gas line Roger General DIY Discussions 2 02-27-2009 07:42 AM
