Running A Ground Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2008, 01:38 PM   #1
Running a ground wire
I wanted to mount an antenna on my roof and was thinking about the ground wire.
The attic is somewhat finished, in that 3 or 4 years ago some electrical service (lights and outlets) was run up there. Can I tie a grounding wire from the antenna into the ground wire in one of the outlets in the attic?
T Blanco is offline   Reply With Quote
Old 01-07-2008, 02:10 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,410
Ayuh,.......
I don't know that you would want to draw a Lightening Strike Into your house,.......
A Straight Shot to the Earth, with it's own Ground wire just sounds Soo much Safer........
Old 01-07-2008, 02:36 PM   #3
wfischer's Avatar
How else would you get 1.21 jigawatts into the flux capacitor?
wfischer is offline   Reply With Quote
Old 01-07-2008, 03:17 PM   #4
But they wouldn't be going 88 mph..
jerryh3 is offline   Reply With Quote
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 08:23 AM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
Open beam ceiling and running wire... Alan Electrical 2 12-10-2006 09:14 PM
Ground Wire Problem ScubaRaven Electrical 11 06-08-2006 02:32 PM
