Running Feed For Sub Panel Heat Duct In Stud Bay? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 05:18 AM   #1
Running feed for sub panel heat duct in stud bay?
I would like to add a sub panel closer to the kitchen for 4 new circuits (remodel) that will be added. At this point I'm unsure what gage cable will be used for main feed. In any case it will have to be bent around 2 heat ducts that fill most of the stud bay I don't see any way around it at this time.
Any suggestions? Should I forget the sub panel and just run 4 home runs to main panel? Kind of hit a wall at this point.
rodm1 is offline   Reply With Quote
Old 11-28-2011, 07:20 AM   #2
Running the sub wire as you describe is probably OK, as long as it is at least 1 1/4" from any surface, and/or protected. But if you have the panel space for four new circuits, why not do it that way??? As I recall, it can run around heat ducts, but not in them.
Old 11-28-2011, 07:22 AM   #3
DIY staff
Rewards Points: 7,174
Need a picture of the route----
If there is not a good reason to have a subpanel in the kitchen--I would suggest four separate lines---
Finding a place for the sub panel could be a problem in itself----Mike----
Old 11-28-2011, 07:49 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,032
+1 on the 4 circuits unless you are short of space in the main panel or it is an unusually long run.
Even if you need the sub I would try to locate it in a non-living area.
Coastal South Carolina
Use FPE Panelas a feed through to new replacement panel. ElectriMan Electrical 16 08-05-2011 02:55 PM
Raising a suspended heat duct dmarek HVAC 2 04-17-2011 05:57 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Feed Sub Panel From Sub Panel jamiedolan Electrical 3 02-03-2009 01:22 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
