Old 01-16-2012, 10:41 AM   #1
Running Extension Cords From Portable Generator
I have a 5000 Watt portable generator that I am using. I don't want to go to the expense of adding a transfer switch (I will someday), so in the interim I am using a special extension cable rated for the generator I own. Problem is every time I use the generator I have to leave the door to the house partially open to run the cord thru. I had an idea that I would mount a 30 AMP power cord inlet box on the outside of the house and connect it to a similar box on the inside of the house that could be connected to whatever indoor extention cord arrangement I needed. Will that work? If so, what type of outside and inside wall connections would be required?
rkwingo is offline   Reply With Quote
Old 01-16-2012, 10:50 AM   #2
You need a 20 amp inlet not a 30.
http://www.northerntool.com/shop/too...0874_200220874
On the inside I would put a twist lock 20 amp outlet and plug in a power distributer.
Old 01-16-2012, 11:58 AM   #3
Thank you for the information!
Powering boiler with portable generator piacentini Electrical 14 01-06-2011 10:01 AM
Extension Cords Types alnoir Electrical 17 10-21-2009 06:37 PM
Running the Generator in the Garage hogger9 Electrical 19 09-26-2008 08:02 PM
Freedom 90 furnance not running reliably from generator jrielsky HVAC 6 02-12-2008 02:48 PM
Running a generator for power outages tropic home Electrical 5 12-04-2006 09:22 PM
