Running Electricity To Kitchen Island - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 08:56 AM   #1
Running electricity to kitchen island
I am in the process of designing our new kitchen. The design calls for a free-standing island that needs electricity for a range/stove. The spot where the island is going currently has no electricity.
The floor is tile on concrete. The house is in Florida (no basement).
How do I run electricity to the island?
michaelkingdom is offline   Reply With Quote
Old 03-11-2012, 09:09 AM   #2
Pure Genius
Rewards Points: 150
You have to bust up your floor and get it there. Or change your design.
Dierte is offline   Reply With Quote
Old 03-11-2012, 09:10 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
You get a concrete saw and cut a channel in the floor, run conduit and patch the floor.
Old 03-11-2012, 09:10 AM   #4
I completely agree, but if there is an island it also needs a receptacle.
Old 03-11-2012, 09:29 AM   #5
Rewards Points: 77
The only other way would be to run it from the ceiling using some design element to hide the wiring. unfortunately anything i can think of would look pretty tacky. perhaps an interior decorator could come up with a good option. otherwise cutting the floor is probably the best route.
Edit: Auto correct issues
dengle is offline   Reply With Quote
Old 03-11-2012, 09:33 AM   #6
Code05's Avatar
Rewards Points: 1,104
Might need 2, check your 2011. Bold is new.
(4) Separate Spaces. Countertop spaces separated by
rangetops, refrigerators, or sinks shall be considered as
separate countertop spaces in applying the requirements of
210.52(C)(1). If a range, counter-mounted cooking unit, or
sink is installed in an island or peninsular countertop and
the depth of the countertop behind the range, countermounted
cooking unit, or sink is less than 300 mm (12 in.),
the range, counter-mounted cooking unit, or sink shall be
considered to divide the countertop space into two separate
countertop spaces. Each separate countertop space shall
comply with the applicable requirements in 210.52(C).
Code05 is offline   Reply With Quote
Old 03-11-2012, 09:49 AM   #7
Rewards Points: 81
How deep and what type of conduit is required to be run?
I'm thinking of putting a bar in my basement which would have openings on both sides thus no way to run electricity unless I put column posts or some other way through the ceiling.
LarryM is offline   Reply With Quote
Old 03-11-2012, 10:00 AM   #8
Certainly true.
Old 03-11-2012, 10:00 AM   #9
Eeeeeewwwwwww
The Following User Says Thank You to Speedy Petey For This Useful Post:
Code05 (03-11-2012)
Old 03-11-2012, 10:12 AM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Eeeeeewwwwwww
4 poster bed concept!!!
Old 03-11-2012, 02:26 PM   #11
Rewards Points: 77
Eeeeeewwwwwww
I did say it would be tacky
Old 03-11-2012, 03:27 PM   #12
Semi-Pro Electro-Geek
Rewards Points: 2,856
PVC conduit at any depth under the slab is fine. Considering your loads, a 1" conduit should be about right.
mpoulton is offline   Reply With Quote
Old 03-11-2012, 03:48 PM   #13
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Install pot lights above it, and solar panels on the counter.
In seriousness, no basement makes this very hard though. So it's straight on the slab, no subfloor/crawlspace or anything?
Another option could be to just have a pole/conduit going up the attic. Make it into some kind of decorative pillar or something.
Old 03-11-2012, 06:18 PM   #14
Currently, the kitchen is basically a room with four walls. Electricity is coming down from the attic. Our design calls for two islands (one with sink and dishwasher, the other with range).
We will either have to run poles or go into the foundation. It looks like the poles would be weird but is cutting into concrete to run electric and water supply lines even possible?
Thankfully, there is a sewer line in place already.
Old 03-11-2012, 06:22 PM   #15
Licensed electrician
Rewards Points: 1,020
Cutting a slab is done all the time, especially in a commercial setting. Be prepared for a lot of dust, even if a wet saw is used.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
Code05 (03-11-2012), mpoulton (03-11-2012), Speedy Petey (03-11-2012)
HELP - kitchen island receptacle yogaf Electrical 6 02-15-2012 07:56 PM
kitchen island GFCI? analogmusicman Electrical 7 02-06-2012 06:41 PM
Securing kitchen island to floor with cabinet levellers jhakkim Kitchen & Bath Remodeling 0 01-02-2012 11:22 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
Anchoring a Kitchen Island darenrogers General DIY Discussions 4 07-16-2010 06:24 PM
