I'm adding an outlet in the back of my fireplace for a fireplace insert. The easiest access for power is if I drill a hole in the brick in the basement and run the wire up through the ash door which is on the floor in the back of the fireplace.
I was planning on using a junction box over the hole that I drilled so that it looks like a cleaner installation. The wire will only pass through the j-box. It will look like a dead end but the wire will come out the back side of the j-box. EMT will be used between this junction box and the feed junction box with NM or bx running in the conduit. Would I need a fitting on the backside of the j-box?
Does this sound like a good plan?
The easier idea is to just run bx off the closest j-box and run through a hole in the chimeny and up and through the ash door. If I opt for this route, do I need to protect the wire at entry point (drilled hole) of the chimney?
TIA
Cliff
TIA
Cliff
